My headlight blew over the weekend. So I replaced both with Xenon super blue/white type lights, 55W. They were $68 for the pair. The difference between these and standard headlights is amazing. I don't see the point in upgrading the headlights to HID. You may as well get these 'legal' Xenon type lights for the suburban road, and use some HID spotties or normal spotties when out bush for additional vision.
I did the same, went for the Phillips White/blue.. massive difference.
Them with the Lightforce HID's on high beam its very well lit up, now for an LED bar..
He was very responsive (got back to me in like 15mins last night), I am however still tossing and turning if it is worth $450ish plus a day of my life to fit them up VS $39 for some Narva 120s. Its a lot of money, big job to fit them and pretty risky. Hmmm... decisions decisions...
It should be that much money because of labour. It's a pretty big job to open a headlight assembly, make a custom projector and mounting for it and put it back together.
I've been down the track of HID kits, been using the Philip x-tremeVision H4 globes - but the globes seem to last only 12/18 months at $70 a pair. Back onto the original OE globes at the moment
All Nissan owners living in poverty are being looked after......
I installed an HID conversion from http://www.delonixradar.com.au/ in WA about 4 years ago. No problems with the kit, it's been rock solid. Rubber boot fits ok, so no problems with water entry. Low beam is MUCH better, hi beam is a disappointment. Have had a few comments from other drivers about glare, even on low beam. Also, the reflectors are a bit discoloured near the bulbs - maybe heat or UV, I don't know.
I'm thinking about going back to conventional with upgraded bulbs.
2007 D4D GXL.Suspension by Ultimate, Minto - modest lift.DIY shelf unit (help from ORS, Narellan).Polyairs.Dual batteries with RanOx smart DC-DC charger.Towing a Kimberley Karavan with another RanOx.
