Along with my engine rebuild the dealer fitted a new main battery after telling me my old one had leaked some acid. The new one is a N70ZZL by Smartdrive, has a Toyota label and identified as Toyota aftermarket, is made in Australia, and claims to save up to 2% in fuel savings. I'm just amazed that it's made in Australia - land of the clever people.
New battery from Toyota made in Australia
Bugger Bali, get out and see Australia before we sell it all to China.Tags: None
Just googled it.... Made by Century/Yuasa.
Seems to me it's just another battery.
Maybe the Toyota / Smartdrive sticker has some benefits?
I am feeling a little cynical tonight....2013 Land Rover Discovery 4 SDV6 SE
Ex 1988 Mitsubishi Pajero V6
Ex 1986 Suzuki Sierra
2% fuel savings is just a little on the hard side to believe Presumably this is over standard, so if its a Toyota battery then why not put them in from new and give us the supposed fuel saving from the start.
Changing the battery can't make you use less power, so the same amount of power needs to be generated by the Alternator, so the only way I can think that the battery can make a fuel saving is if its lighter, but 2% I don't think so.
got a pretty new (~4 months old) century battery in mine... has a sticker that makes the same claim... i believe the caveat is if you have a "smart" charging system... like one that can either clutch out the alternator once the battery is fully charged, or completely unload it... hence reducing the load on the engine... i don't know, any benefit would have to be minute... even a 2% claim seems a bit high to me.
[edit] heh, BEATEN![SIZE=1]Graphite 120 GXL V6 Prado, ARB Deluxe Winch Bar, ARB/OME 2" Suspension Lift, BFG 265/70/17, Uniden UH7760NB + GME Antenna
32" Dual-Row LED Bullbar Mounted Lightbar, 42" Single-Row LED Roof Mounted Light Bar, Rhino-Rack Pioneer Roof Rack, Sony XAV-63[/SIZE]
Well, I managed to save 9 weeks of fuel expenditure thanks to Toyota's duff injectors blowing my engine. That's how long it took to fix.Dave
Originally posted by Moz View Postgot a pretty new (~4 months old) century battery in mine... has a sticker that makes the same claim... i believe the caveat is if you have a "smart" charging system... like one that can either clutch out the alternator once the battery is fully charged, or completely unload it... hence reducing the load on the engine... i don't know, any benefit would have to be minute... even a 2% claim seems a bit high to me.
2% saving in fuel - load of BS, IMO.
[edit] heh, BEATEN![/QUOTE]2014 D4D 150 GXL Automatic - CHARCOAL
Could also be:
1/ Lower internal loses when fully charged.
2/ A full calcium battery which will never fully thus lower internal loses
3/ Slower charging rate (possibly as per note2), and less current surge after starting.
/ Sales hype as how can you measure it to prove otherwise but then maybe I'm just
being cynical.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
