Dodgy Ambient Temp Display
    Mine too, I am quite often below sea level, thats why I fitted a snorkle....ha
    Be interesting to see what it does tomorrow, the forecast is for 43!
      Mine said -50m sea level. That's a long snorkle.
        I think my temp guage is broken, today it read "50". It only feels like 45.
          Mine read 50 a few weeks ago
          I think it was broken cause it felt a lot hotter than that
          I read somewhere they only go upto 50, with this current weather I might find out if they go higher.
            mine the other week down in Victoria read 46 a couple of hours after going up Billy Goat Bluff..witha peak of 47..
              Originally posted by Bluebox View Post
              My Altimator tells me that I am under water most of the time?? Lol
              i only have a GXL, so mine doesn't have the altimeter.
              The errors depend on where your altimeter gets its data from. If it's the GPS, the geometric altitude should be accurate to within a couple of metres most of the time. If it uses an uncompensated barometer, then it'll only show variation from sea level pressure.
              Typical sea level pressure is about 1013hPa. For each hPa either side of that, you will get 30' change in your altimeter. So, if you,re sitting at the beach, and the atmospheric pressure is 1021hPa, your altimeter will read (1013-1021)x30= -240'.
              If you're unlucky enough to be sitting on the WA coast where/if Narelle crosses, your altimeter would read about 2400'!
              [i]I remember when sex was safe, and flying was dangerous![/i]
                Mine still seems to be a bit dodgy (understatement?)
                Between 15 and 30 it seems to kinda work but it was 40 here yesterday and it only read 30.
                Its supposed to get to 45 today so see what happens, apart from my abject misery dealing with this heat!!!
                1coolbanana
                  Glad I'm not alone in this - mine just started saying -30!
                    8:30am yesterday morning, yes that is the correct temp, going to be hotter today
                      Ours had 50 on the dash the other day yet our temp was 54 so Andrew you might be correct on only going to 50.
                      2008 Prado GXL D4D Auto Silver, 265/70x17 Mickythompson ATZ 4 ribs, ARB delux Bar Avenger Mako 9500 winch, TJM XGS Gold suspension, Poly airs, Safari Snorkel, Dual Battery system, Voltage Booster, Lightforce XGT lights, GME TX3100 UHF,ARB CKMA12 Compressor, ENZD special quad breather kit,Outback Draw system 1/2 Cargo Barrier,Kaymar duel wheel carrier,AJ120 Sliders, Taipan XP Exhaust, Twin E Lockers, Foxwing, Pioneer Platform.
                        I got close to that limit yesterday:
                        Happy news on the radio too, Adelaide is the hottest City on Earth!!
                        Micheal.
                          Well, mine magically fixed itself today! Go figure!
                          • #28
                            After the last few days of very high temps mine still reads between 20-22.
                            Damn thing is a waste of time :-(
                            • #29
                              Does anyone know of the part or where it is located?
                              • #30
                                Its at the front of the radiator on the centre part at front.
                                I tested mine and its fine, its unfortunately the display unit in the cabin that is the problem in mine and Im guessing everyone elses :-(
