I did a search, and didn't come up with much. I've got an intermittent issue with my Prado. Its a 120 Series V6 auto.
I was driving along, and the battery warning light came on, then a few minutes later (I couldn't pull over, but the car was running fine) the Check Engine Light, the ABS light and the Handbrake light came on, and my speedo dropped out.
I pulled over, turned car off, and turned it back on, and its fine. After a few minutes it does it again. I drive the 5 or so minutes back home, test the battery / charge rate with a multimeter, and the charge rate seems to be up around the 16.5-17 volts mark.
So i finally get around to installing the ScanGauge i bought last week, and scan for errors. a P0500 came up, and I did a search on here and found its "Vehicle speed sensor “A” (open/short/failure) " Ok, so what the hell is that?
I've been driving the car, and no issues, until last night, the voltage on the SG went up to around the 16.5-17 volt mark, and the battery light came on. (It seems as soon as it hits 17volts, the battery light comes on). CEL is also on. Again, a P0500 code comes up.
So, any ideas? The speed sensor would account for the speedo dropping out, but the voltage spike? Any ideas?
Anyone had anything like this before?
Cheers, Damo
Cheers, Damo
