G'day. I have been through the forums, but can't seem to find a solution to my problem. The problem is simply that the brake lights don't work! I have checked/replaced the 'stop' fuse under the bonnet, but to no avail. Checked the globes, all work when wired direct to a battery. I checked the peddle switch, and it also is working...in fact, when I put a test light across the 'stop' fuse, can see the voltage change on the peddle push.
This has really got me stumped...it appears there is no power to the wiring at the back. Is there another fuse? An inline fuse perhaps?
I have only just noticed the lights, after I checked them after connecting the trailer, so not sure if that caused the problem, but I assumed even if it did, it would be the fuse!
Any ideas?
Any ideas?
