Should I have a green warning light come on when my lights are on next to the main beam warning light on the dash?
If so does anybody know what bulb it takes please? Thanx
Scruffy. I don't have fog lights but a while back the green light came on whenever my headlights are on, Has been like that for a while now and to be honest i haven't been bothered trying to fix it, Lights work as there meant too.
I think crap in one the fogs light plugs up front is the cause of it.
You may just have the fog light knob switched to 'on'. The fog light switch is on the headlight/indicator stalk. If you don't have fog lights installed it's probably a good way to notify you that your headlights are on, if you like that kind of thing.
[size=2][b]Prado 120 - 2004 GXL V6[/size][/b]
[size=1]ARB deluxe bar, OME 2" lift, Safari snorkel, BFG A/T's, Ironman winch, LED bar, Redarc DC-DC dual battery, Rhino Rack Pioneer tray, Outback drawers and plenty of goodies inside. [/size]
LOL i have a switch ? :O haha never knew :P That explains alot m8 thanks.
Mine (2003 Grande) has a light that comes on as soon as the parkers are on. It looks like this
It is located directly to the right of the '5' in the tacho.
Although I have foglights as standard, there isn't a foglight indicator in the instrument cluster.
[ATTACH=CONFIG]19879[/ATTACH]
Interesting, neither my 05 or my current 09 had that light, might be a Grande thing maybe?
I've had a closer look and I can see the fog lights symbol etched into the instrument cluster in the same spot as your photo. What I also noticed is a mirror image of the fog light symbol to the right of high beam. This one should be for the rear foglight.
I wonder if my front foglight indication bulb is missing or blown...
Maybe ask someone like Macroon1, I reckon he has an ) 03 Grande as well, that may help with an answer.
The green fog light indicator wasn't used prior to circa July 2004, even if the car had fog lights and even though the etching is in place. I don't know if it was the case that simply the bulb/LED wasn't included or if it was the entire cabling/wiring that was missing.
That's what I can see in my cluster but it does not illuminate! However it is an 08 GXL - thanks
