No OBD2 COMS - ECU Issue?
  • No OBD2 COMS - ECU Issue?
    Hi all,
    I had a search, but couldn't find any similar questions or answers on my problem.
    So, I bought a 120 Prado, 07/2003 build, 4ltr V6 Auto... and the remote on the key's wouldn't work, the seller said he just hadn't had them programmed.... yea right.
    So, I too it to Toyota to ask them to program the keys for me, but the said they couldn't talk to the ECU with their scan tool.
    I'm an ex mechanic, so I have my own simple scan tool, and it cant communicate with the ECU either.
    So, my question is: The vehicle runs fine, all functions are operational and it runs like a dream. But, I cant talk to the ECU.
    Has anyone else had this problem? Could it be the ECU or something more simple?
    (I've visually checked the wiring behind the OBD2 plug, and they all seem un-damaged etc, and I'm not keen on having to do continuity tests on every cable between the ECU and the OBD2 plug if anyone else has come up with a similar problem?
    Thanks in advance.
    Steve
    Early 120s were not obd2. They have an obd2 plug but it runs on a different protocol.
      Early 120s were not obd2. they had some sort of Toyota only system. I think I have seen this before for the remote, involves putting the keys in and opening and closing the door ect. Should be able to Google it..
        there you go,,, http://automechanician.blogspot.com....20-3rz-fe.html
          The dealer should still be able to talk to the car with their software Techstream, hopefully he didn't bugger that step up... Perhaps check that all the wiring around the ECU is ok. If a UNICHIP or some other piggyback was fitted at some stage they may have compromised the wiring at the ECU.
