Hi
Initially I added a plug and play 35W 6000K HID hi and lo kit from these folks
http://www.hidworld.com/cart.php?target ... ory_id=250
Easy enough to fit but the forward beam penetration is just OK because of the headlight beam pattern.
Next I've installed a pair of Narva 225's driving lamps (with a Narva harness etc) - spot and spread beam combo's converted to 55W HID from these nice folks - and yes on a level straight road it will illuminate 3km's!
http://predatorparts.com.au/lighting.html
Now the query I have is - to operate the driving lamps I have to switch them on and off via the standard Narva switch, they operate after the headlights are turned on but I would like them to operate when I flick the high beam stalk and use their switch to turn them on or off should I so desire.
The nearside standard headlamp connector is plugged into the hi/lo HID harness and I've derived the live for the driving lamps from the offside headlamp connector cable which is live when the high beam is operated.
Help!
Help!
