Re: Redarc BCDC-1220 20amp DC-DC 3 Stage Battery Charger Install
bilo33prado,
The large "jumper lead" cables serve two purposes on a solenoid system:
1: the larger diameter cable reduces voltage drop, supporting faster more complete charging of the aux. battery.
2: Most solenoid systems have a manual over-ride which can be used to enable cranking off the aux. battery, in which case the heavy gauge cables are required to support the high currents during cranking.
When a DC-DC charger is used, voltage drop becomes a non-issue (the whole point of using the DC-DC charger) and it is not possible to crank off the aux. battery through the DC-DC Charger (This can be achieved with a bypass circuit). So there is no need to have the very heavy gauge cables. The cables simply need to be able to carry the DC-DC supply current which is usually around 30A.
Leachy
bilo33prado,
Leachy
