V6 - Intermittently hard to start
    Re: V6 - Intermittently hard to start
    My guess is that it could be a bad earthing point - especially when you said that it gets worse when its hot and that the the error message said that there was no ECU present.
    If one of the sensors or wiring to the senors were crook, the ECU should come up with a fault relating to that sensor.
    Best of luck sorting the problem out
    White 2003 V6 GXL, 4spd auto, Vapor injected LPG, Autocraft Prem Billstein 2inch lift with poly air-bags
      Good news. I've got my Prado back.
      The service centre could only test when the start circuit faulted - so it took a little while to find the problem.
      They
      - checked the start circuit from ignition to ECU
      - checked the electrical connectors between ECU and ignition
      - checked the electrical connectors between ECU and motor
      - checked the wiring harness through firewall
      - checked the EFI fuse, relay and circuit to ignition
      - checked the auto trans switch
      - checked electrical connectors ECU to instrument panel
      - checked electrical connectors from engine bay to ECU
      ...... and found a loose wire in one of the connector blocks to the ECU.
      One wire, loose in its crimped connector, was making partial contact.
      The connector was fixed and now the car starts.
      Chippy
        Finally an answer. I bet you are happy that something wrong was found and now all is good. :lol:
          They
          Chippy
          Great stuff. I bet that is a relief it is over. Just a question though, who pays for the parts that were replaced that weren't the cause of the problem. Is there any come back there.
            Chippy,
            Excellent news - bet your glad to rid of that loan camry/corolla.
            I hope the right price is charged for the delays etc, esp if they started replacing bit & pieces as a trial & error process.
            As is often the case simplest things usually cause major dramas.
            2008 GX turbo diesel auto 5sp Fitted: snorkel dual battery kit kaymar twin wheel carrier Evenutally fitted: Bullbar VHF & UHF radios, storage system Still to come: winning lotto number to pay the blessed thing off set of decent side steps/rock sliders
            Too many projects so little time and even less money
              Great to hear the bus is back on the road Chippy
              The symptom you describe, "Heaps of electrical power .... but no noise. No spinning over - No CLICK" kind of reminds me of the situation where people use non genuine keys in 100 series cruisers. The genuine Tojo key uses a coil to energise the internal chip in the key that disarms the factory immobiliser. The cheap non genuine ones use a battery and when the battery starts to go flat, guess what! intermittent to start with, then as the battery gets flatter, eventually the car doesnt start at all using that key.
              I know the prado uses a replacable shell type but for those who use a "non genuine" service key style, this maybe something to consider.
              If your car wont start occasionally and you have bought one of these style keys, if you have another key, try using the other for a while and see what happens.
              Nothing like having the problem in your hand (so as to speak)
              Terry
                Hi Terry,
                I think you may have diagnosed my problem. I have 2 keys and I marked them. Then I drove around for a couple of months on one key. Absolutely no problem with starting. Then I started using the 2nd key and within a few starts, the problem returned. Swapped back to the 1st key for another few months and never had a problem. Swapped to the 2nd key and the problem is back. Will try and change the battery in the 2nd key and see what happens.
                  Andrew,
                  No problems, glad to be of help!
                  Let us know how it all goes.
                  Terry
