LED worklight
  • LED worklight
    just wondering has anyone installed a LED worklight on the rear door or rack, was looking on ebay and found this 1, whats ya thoughts, looks like a pretty decent unit, just wondering about light output. cheers samo
    http://cgi.ebay.com.au/LED-Camping-Ligh ... 335d97b2a0
    Re: LED worklight
    Hi Samo,
    I have one that has about 20 LED in it, is ok for hitching up the van etc but you would get
    a lot more light from a 50W halogen. But then the led light uses a lot less power.
    Would give about the same amount of coverage as your reversing lights do.
    I would go for the LED lamp with the highest output you can get ie 15W or 24W,
    unfortunately there not cheap.
    hkbelect
      Re: LED worklight
      thanx leigh, was wondering how much light they put out, i think i will stick with the old hella 181 for a work light, save myself some coin lol. if only they made led lights that put out as much light as halogen for a good price. cheers samo
        Re: LED worklight
        Hi Samo,
        I looked at these about 12 mths ago...
        I was surprised at just how bright they were..... :shock:
        http://www.narva.com.au/products/browse/led
        Part No./Description
        72466
        'Delta' 9-36V Multi-Voltage L.E.D
        Work Lamp Flood Beam
        Features: Utilising the latest in ultra reliable L.E.D technology and designed for the most grueling environments. Fully sealed (IP68) with a pre-wired die-cast, powder coated aluminium housing
        •10 x 2 watt high powered L.E.Ds producing 2000 lumens
        •Virtually unbreakable polycarbonate lens
        •4mm steel multi-angle mounting bracket
        •Minimal power draw, 1.75A at 12V, 0.85A at 24V
        Rod
        Black 2006 GXL TD - Brisbane
          Re: LED worklight
          thanks rod i will check it out. cheers samo
            Re: LED worklight
            We have changed from halogen to led work lights at work & the led lights are much better than the halogen but are not cheep.
            The light spread is a lot better and for our operation we mount them in a fixed position.
            From memory they are a 9 led light.
            Chuck
              Re: LED worklight
              thanks chuck, what do ya call no cheap, about $400ish. cheers samo
                Re: LED worklight
                I have been looking at them for a while trying to decide whether to try one or not. I think the light output would be enough
                I also have been waiting for these to come down in price
                http://cgi.ebay.com.au/40-LED-120W-s...item3cace0e486
                December 2007 Prado GXL diesel, Option Pack with traction control, rear airconditioning and curtain airbags. Lovells Springs and Bilstiens shocks, snorkel, front recovery points,
                ARB Bar with fog lights, ARB second battery system, sandgrabber mats, Pirelli ATR Tyres,
                  Re: LED worklight
                  Samo I think they were around the $300 mark.
                  I see there are some at Ashdown-Ingram not sure of prices though.
                  They did have the Redarc 12 volt charger $100 cheaper than I could buy it locally.
                  Chuck
                    Re: LED worklight
                    I just put one on the top of my rear door above the diy fold down camping table. It has 121 LED's with a 120deg light spread. The dimensions are 600x25x10 and looks the part. Very bright! I think it cost me about $120.
                    [INDENT][CENTER][SIZE=4][B][URL="http://pradopointgtg.org"][COLOR=#000080]PradoPoint GTG 2014 - [I]Iconic High Country - Victoria[/I][/COLOR][/URL][/B][/SIZE][/CENTER]
                    [CENTER][SIZE=3]Big Thanks to Our Sponsors - [/SIZE][SIZE=4][COLOR=#ff0000]ARB 4x4[/COLOR], [COLOR=#800080]Dobinsons Springs and Suspension[/COLOR], BCF, [COLOR=#008080]Terrain Tamer[/COLOR], [COLOR=#696969]ORU[/COLOR], [/SIZE][SIZE=4][COLOR=#ff8c00]Maxtrax[/COLOR], [COLOR=#0000ff]Traxrax[/COLOR], [COLOR=#800080]Brains[/COLOR], [COLOR=#ff0000]Redarc[/COLOR], [COLOR=#008000]Opposite Lock[COLOR=#222222], [/COLOR][COLOR=#0000ff]Kaymar, [/COLOR][/COLOR][COLOR=#ffa500]Hema Maps, [/COLOR][COLOR=#ee82ee]pure-sense, [/COLOR][COLOR=#696969]Bushskinz, [/COLOR][COLOR=#ff0000]Piranha Offroad [/COLOR][COLOR=#800080]High Country 4x4 [/COLOR][COLOR=#222222]& [/COLOR][COLOR=#808080]Century Batteries.[/COLOR][/SIZE][/CENTER]
                    [/INDENT]
                      Re: LED worklight
                      Where did you pick it up from? Type?
                      Manata 3" Exhaust, Blisten shocks, King Springs 50 mm lift, Poly Air Bags, Roof Rack, Iron Man Bull Bar, HID 50W LightForce XGT spotties, Daul Batteries, GME TX3440 & AE4705 ant, Upgraded window washer, Bonnet Scoop, Tunit chip, bonnet protector, headlight protector, Cooper STT's, ScangaugeII, Dash Mat, Endless Air, Stebel Nautilus, Diff Breathers, Water Sedimentor. ([b]Camprite TL8s [/b] Arrived ALIVE~!)
                        Re: LED worklight
                        I got mine through bursons, they ordered it and it was there the next day. Have a look at http://www.ledautolamps.com. It's white and slimline and comes in a few different lengths if you don't want as many LED's or as bright.
                        [/INDENT]
                          Re: LED worklight
                          10w leds are now out it seems
                          see here
                          http://www.adventureproducts.com.au/...itz/cat_8.html
                          cheers
                            Re: LED worklight
                            8) yeh i put a 10watter on my kaymar worklamp bar on thursday its a better light than the big 55 watt halogen that was on it,looks just like the first one on the link
                              Re: LED worklight
                              Here's a couple of shots i took of my LED light as per the previous posts whilst at Burra Gorge on the way to Alice.
                              [/INDENT]
