Partnumber for ABS connector front ?
  • Partnumber for ABS connector front ?
    Hello everyone!
    Some days ago, I changed my wheelbearings.
    Both ABS-sensors broke (front) , bad enough.
    I got everything working, but the seals in the connection plug (where the wire connects to the ABS sensor) is broke (fell apart complety!).
    As I need the car every day, I removed the rest of the seal and plugged it together with grease to protect it a little bit.
    We have wet winters here in Germany, lots of salt on the streets - this is no long therm solution.
    Can anyone help me out with the Toyota partnumber for the seal or the plug (complete with seal) ? Need it for the front ABS sensors.
    I need to order some parts from UAE, and if I had the part number, I could order the connectors or seal with it.
    Thank you for your help!
    Reno
    Here you go, 90980-11003
    https://www.amayama.com/en/part/toyota/9098011003
      Originally posted by adrian5800 View Post
      Jesus,
      that was fast! You are really great, thank you very much!
      Have a nice day ,
      Reno
        Originally posted by Reno1986 View Post
        Jesus,
        Have a nice day ,
        Reno
        No worries. Glad to help
          Hello again,
          damn it! It's not your fault, because I rechecked for the number.
          There must be sth. wrong with the Toyota documentation. The connectors are the wrong ones, sorry.
          Do you have any chance to get additional info or another part number for me?
          Thanks a lot
          Reno
            Hello again,
            Thanks a lot
            Reno
            Sure, what's your model, year and VIN?
              Hello again !
              I have a 2006 D4D J125.
              VIN is JTEAZ29J200039024
              I'm curious what you can find out !
              Thanks for help,
              Reno
                All I can suggest is the wiring diagram I posted above is listing the connector on the main harness in the engine bay, not the one at the wheel sensor and perhaps the sensor connector at the end of the short ABS harness is not listed separately.
                Each front wheel has a short harness which aren't too expensive. Otherwise find a wrecked J120/125 in your area.
                  http://www.japan-parts.eu/toyota/eu/..._abs-vsc#89516
                  Last edited by adrian5800; 18-01-2019, 07:01 AM. Reason: Stupid vbulletin wouldn't let me post a URL...
