Kings wiring harness switch upgrade
  • Kings wiring harness switch upgrade
    Has anyone gone to the trouble of upgrading the switches on the king's "smart" wiring harness for light bars etc?
    The standard rocker switches apart from being ugly, dont fit nicely (by nicely I mean they don't fit at all) in the 120 switch blanks.
    I want to upgrade to Narva style switches but can't find any info about what pin on the king's switch does what. If anyone has this information I'd appreciate it
    I could strip down the harness and figure it out, but If I'm going to the trouble of finding out what wire does what function on the king's gear I may as well just redo the wiring from scratch, as it will give me 3 benefits, 1) I'll know exactly what wire does what, 2) the wiring will be the correct length without being coiled up somewhere, and 3) I'll be 120% certain the wiring is of good quality.
    Why didn't I do this first? Well because the lights came with the harness cheaper than just the lights by themselves. And because time was of the essence when I installed them..
ID:	766844Click image for larger version
ID:	766843 Dredging up an old post but how did you sort this please?
    I have exactly the same issue and wondering if I can use this switch:
    https://www.repco.com.au/en/globes-b...m=cpc&region_i d=100241&gclid=EAIaIQobChMIyIKKgoHM_AIV2X8rCh38Ugh 9EAQYAyABEgKYSvD_BwE
    Not sure which wires would go into which terminals on the new switch…
    Kings switch, with blue, black and white wire and new switch wiring diagram.
    thanks!
      About Kings wiring harness switch upgrade
      I stripped down the Kings Smart wiring harness and found out the following: (I also upgraded my switch to a Navra O.E switch)
      On the Kings wiring:
      White: DC in
      Blue: DC out
      Black: Light for switch (not needed if your new switch doesn’t have a Light display i.e. a standard rocker switch)
      With most other switches like Navra that have a built in light into the switch to indicate that it’s on: You will need an Earth for the light on the switch to work
        Just saw that I had a reply...
        No I haven't sorted this out.
        @adenc4
        Is the black on the king's harness the earth for the replacement switch as you mentioned or is the black a power input?
