Has anyone made a battery tray/mount utilising the rails from the 3rd row seats?
  • Has anyone made a battery tray/mount utilising the rails from the 3rd row seats?
    Thinking this would be a solid place to secure the fridge battery.. just gotta work out how to do it
    Good idea, are you thinking false floor and a slimline lithium battery?
      Yep mate, exactly. Just trying to nut out how to fit the battery tray itself to the bar that the seat used to attach to. I have some ideas but they are a bit hazy, want it solidly mounted.. thought I'd see what other people have done - cheers
      PS will be a 240ah battery. It should easily fit in the hole between the fridge and sidewall OK (it's pretty skinny). Still waiting on delivery for this one
        Do you want to use the catch that holds and hinges the 3rd row seats on the sides of the cargo area. I used them on one side to secure a false floor in place. I'll see if I canfind the photos.
          This is how I made shelf for rear using the seat catches. Rod is same diameter as the seat mount and the length is same as seat so it doesnt move about. shelf frame held by seat catch and another cam over catch on fridge slide frame
ID:	764298Click image for larger version
            Thanks mate, that looks pretty tidy..
            Was thinking I could use the existing bolts.
            Current plan is to get a 3mm piece of flat steel bent at a 90 degree to attach to the outside of the fridge slide and angle over to the bolts.
            Can extend the existing bolts with threaded rod to suit height..
            This should give a solid platform for creating a battery box
            I'll try to attach a pic..
              Depending on what state you are in but removing the fixed seat mounts may be a defect notice. If thats not a worry , that mount should be strong enough to hold a battery, may just easier to trim back the plastic to height of mount.
                Good point about the defect notice. The whole thing will end up being boxed and carpeted so it'd take a bit of work to spot
                Even then I'm guessing I could remove the tray, reattach the seat mounts to clear it and put it back together afterwards if I needed to
                the plate steel base tray is the best concept as yet (thought about welding some unistrut for a frame etc) - would be interested to see if anyone has a neater or just plain better idea that I could use?
                  Why not use a length of low profile unistrut, drill 2 holes to match position and spacing of the seat mount bolts and bolt the battery frame to the unistrut. That way the mount bolts are hidden and the unistrut will spread the load.
                    It's a good idea
                    I had thought along these lines and possibly use a bit of heavy cable tray with it as well
                    Problem being I need to right angle the -other- side (fridge side) 90 degrees and down to floor level to secure it so it has two pints of attachment
                    Trying to avoid bolts as much as I can because they can rattle loose and I can't weld to save my life... unless you can get unistrut in a 90 angle and I just haven't seen it (entirely possible)
                    I guess I'm just trying to get the thing rock solid first go and then I can forget about it
                    Need to do something soon tho - esky beer works but fridge beer is better haha
