Re: HID Bi-Xenon High/Low Beam Installation
How are you triggering the relay for the driving lights ? eg the coil needs a positive and negative to pull in, I have seen things like this before related to the pick up point for the trigger, what i do is pick up the positive and negative off the highbeam headlight circuit just at the back of the headlight, never gives any trouble that way. I doubt the ballast ( high voltage )would be impacting on the driving light relays, if it was i think it would probably be effecting other things also. Check the simple things first :wink:
