The filter it comes with is ok without power loss. I'd suggest you change your factor filter at the same time so both filters are brand new and in known condition. You can change to the 30 micron filter when the filter change is due.
I've used the 5 micron filter that comes with the unit for 40 000km without any issues. The only reason I've after the 30 micron unit is for peace of mind that I'm not placing any additional stress on the injector pump.
From what I've read, the the injector pump contains 2 pumps, a lift pump to suck from the tank and a high pressure pump to presurise the common rail.
