Hi all,
what's the minimum idle setting supposed to be for a 2008 GXL diesel? I bought a second hand Prado with 135K on the clock about 3 weeks ago and notice that the idling varies betwenn 650rpm and 800 rpm. Everytime it drops under 700rpm (e.g. when sitting at the lights) I experience a lot of vibration like the motor is about to stall (however, transmission is an auto). It then seems to correct itself by upping the idle speed to between 750rpm and 800 rpm for about 5 seconds before dipping back down under 700rpm again. The cycle continues until I start moving again and everything seems fine under normal driving conditions. Issue only happens when I'm sitting at the lights...
