On my 4th round Oz trip( 2007 Prado Grande Diesel with 110,000km) I was 120 km out of Kununurra cruising at 100kph on the bitumen when I lost all power with Slip Indicator, VSC TRC, ABS and Engine warning lights on. Engine was idling but could not apply power to the wheels. Turned ignition off/on a few times and regained power but warning lights stayed on. Toyota Kununurra cleared the following fault codes-P504,P571,P1251,C1725,C1727,C1728,C1727,C1223,C124 6 but could not identify a cause. Faults did not reappear on test drive so drove 4000km back to Sydney with no other dramas. The main concerns are the computer integrity and the P1251 fault( turbo stepper motor problem) as the after market exhaust broke at the turbo pump flange and I had to drive it 500km to Kununurra to be fixed just before the above problem happened. The repair seemed to be done well without needing to remove the turbo.
Any suggestions on the cause or what I should do before heading off on my 5th round Oz trip?
