Hey guys i am getting the cooling system overhauled by Toyota cause believe it or not their prices were quite good can you let me know if i am missing anything
Radiator and block flush
New radiator hoses
New Thermostat
New water pump
New coolant super long life
Pressure test cooling system inc radiator
Test viscous coupling and over haul if required
I was told they would inspect the radiator and if it looked ok they would pressure test and re use as it should be good for eva
As they have it apart they reccomended doing the timing belt and tensioner even though it is 50,000 early
Is there anything i have missed car has 240,000 on the clock with new injectors at 200,000 still runs like a dream
New radiator hoses
New Thermostat
New water pump
