Hi all
Trying to get all this turbo diesel stuff straight in my head - just upgraded from an old 3L 2.8 diesel to a 1KZ-TE 120 series Prado.
From what I have read so far, the EGR outs a lot of crap into the intake system and needs to be cleaned out. To overcome this I was under the impression that a catch can or blocking the EGR would work.
A bit more reading shows that the EGR valve is one one side of the block while the catch can would be installed between the pipe from the rocker cover to the intake side of the turbo.
How does a catch can help reduce the problem of the crap building up in the intake. It makes more sense that blocking the EGR system is actually going to make a difference.
What's the link I am missing between the two.
If the pipe between the rocker cover and turbo is recycling the oil mist that forms at the top of the engine, then that would mean that the intercooler most likely has a lot of oil collecting in it as well. Would the intercooler benefit from a good clean out as well?
I was thinking of just putting in a catch can, but I now think that I need to block the EGR instead - or should I do both?
Thanks for any clarification.
Mick
Mick
