120 series prado overheating issues
  • 120 series prado overheating issues
    Hi all,
    My name is mark just wondering if any one has any ideas or has seen this issue. I have a 1kz motor and the temp guage was going up when towing at 100kmh then when I back off the temp gauge instantly goes back to normal.it did it again today but this time I was not towing. Ive checked the basics like coolant level which it hasnt used a drop in 6 years no leaks radiator seems to have air flow. And fan seems to be turning.im not sure where the thermostat is on it to check it for restriction. Any advice would be appreciated.
    Cracked heads are not unheard of with the 1kz.
    Other than that, thermostat, radiator blocked or fan clutch not working are the first things I would look at.
      You weren't pushing against the wind in that 45 degree heat the other day were you?
        mine was getting a bit warm when the water pump was on the way out
          Sounds like the the radiator may be blocked, particularly if it hasn't been looked at in 6 years.
            Originally posted by markkab View Post
            Hi all,
            When you say temp goes up, by how much ? Have towed 2 1/2 ton with mine in air temps in mid to high 40's and temp only rises about 3 to 4 needle widths and is nothing to worry about. Have done 212,000 klms so far since 2003.
            John
              Thanks all flushed radiator seems to have fixed the problem..... guess I should have done that earlier.
                Yeah it was going up to 3/4 have flushed radiator seems to have fixed the problem
                  ^^ and install a quality temperature gauge and check/replace radiator cap it may not be holding correct pressure
                  2018 GXL 2.8 1GD,
                    Im a big fan of extra gauges or madman/scanguage, something to monitor real temps, not just the dial, it only starts moving when its really hot
                      Also, my mechanic tells me that he has replaced quite a few Prado radiators at about the 6 year mark with corrosion att he bottom on the OUTSIDE . ie the aluminium starts to break up. This could mean less efficient cooling. About $250 aftermarket [ $700 ish genuine].
                        My 1kz radiator failed in year 10
                          1800km through 47 - 49 degree heat yesterday and scan-guage reading 94. Think my cooling system is working fine.
