diesel rattle in D4D Prado
This is a sticky topic.
  • Re: diesel rattle in D4D Prado
    I was told from a Toyota Employee that the problem should only effect ones with a Build Date pre March 08.
    2014 D4D 150 Prado soccer mum mobile
      I hope they're right!
      [B][SIZE=4]ntp
        Me too, I have a build date of 12/08. :|
        2008-12 D4D 5-Spd Auto Grande, Silver Ash, Full Window Tint, H-R Towbar, Cargo Barrier, Rhino-Racks, Rola Vortex Tray, GME TX3340, ARB Deluxe Winch Bar, IPF900XS Spotlights, BFG 275/65R17
          I have a 10/07 D4D (for about 6 weeks or so) and so far have not noticed any rattle (fingers crossed)
          Just dropped my Prado into Toyota for a Radio replacement and mentioned that some have had problems
          The service bloke mentioned that yes, this has been noticed and put it down to "overinjection of fuel at cold startup" He mentioned that a Reprogram of the computer could be done if it was a real problem but seemed very reluctant to offer this and stated that hopefully in Brisbane we won't get too many.
            Hi All,
            Had the ECU reflashed today and fuel injectors still in within spec, will see how it goes after 1 or 2k km,s.
              Originally posted by masso
              Likewise , I have avoided this thread for some time...i think i am in it about 30 pages ago! Had one injector replaced after much knashing of teeth. And yes.... guess what... its been slowly increasing again... I noted from the injector data that two injectors were not right on the knocker.. but only one was "outside spec"..so they replaced. It DID make a big difference.. but yep..its come back to the stage where its noticeable again... even after it warms... on slight trailing throttle, i can pretty much make the ball bearings in a glass sound! NOT a talent i want to refine ! So i guess i am back here in my""favourite"thread again... off to dealer.. 70K on the clock... expect the same hoop jumping.. so watch this space!
              Rick
              Been to large Toyota Dealer in northern Brisbane... mentioned the whole history of the car, and got the standard "reflash of the ECU - see how it goes in 1000K" which the cynic in me means... " reflash the ECU and hopefully you wont bother to come back" So reflash done... no difference... and have a next door neighbour with new D4D that i drive with occasionally..and the difference is marked! I think after a while you actually get used to the noise.. maybe thats what toyota hope? anyway... call tomorrow to let them know the 1000k didnt work... will post progress.
              Rick
              2010 D4D GXL auto.: 275/65/17 BFG's /ARB Colour Coded Deluxe Bar / IPF fogs / IPF XD Driving lights / OME Suspension / ARB Towbar / Electric Brake Controller/ Safari Snorkel / "Clark Rubber" Mudflap extensions / GME UHF with town and country antennas / RMW Seat covers & Dash Mat / Full window tint/ ARB~Outback Modular Drawers and Fridge Slider/Cargo Barrier/ ARB Dual Battery Installation with rear outlets/HD Rhino Roof Racks..
                I have the tailshaft clunk (since new) and and shake when stopping since new (slip into neutral and back and it stops) From others it seems to be an engine mount, but can't convince the dealer about it yet.
                Just had the 40000 service and they have just greased the tailshaft again (which wont fix mine as they did that every other service and it did it straight away) and now reakon the shakes are injectors. They want to replace 2 injectors, so will see what happens
                Mine is a dec 08 GXL
                cheers
                December 2007 Prado GXL diesel, Option Pack with traction control, rear airconditioning and curtain airbags. Lovells Springs and Bilstiens shocks, snorkel, front recovery points,
                ARB Bar with fog lights, ARB second battery system, sandgrabber mats, Pirelli ATR Tyres,
                  cheers
                  Dec 08 or Dec 07 ? your sig says 07.
                  Cheers, Wayne
                    Rick
                    Rick
                    Hi Masso,
                    I will be watching with interest
                      Rick
                      Rick
                      Hi Guys,
                        I had the reflash done in early June. On cold mornings it had the rattle for around the first 2km of driving. It wasn't actually rattling (weather was warmer) when the reflash was done so there was no real difference that I could tell.
                        Have now done around 8K since, including through the colder winter months (here is Sydney at least) and still no problems.
                        So fingers crossed that mine has been repaired....
                        It is a Sept 07 build
                        Ron
                        07 Prado GXL, D4D manual, silver ash, Sovereign bullbar, towbar, spotties, dual batts, BFG A/T, sunroof, TXE 4400, window tints, headlight & bonnet protectors, floor mats, Navman MY60T, 2" Ultimate suspension, Polyairs, snorkel
                          As well as older diesel Prado, we have late model Hilux, same engine as D4D Prado, 2+ years old, which had severe rattle on startup. Fix has been done, by dealer free of charge, after many months of waiting for Toyota. They simply reprogrammed the Computer.
                          Fix appears to be working! so far!!
                          Next step would be injector replacement. Hope this helps.
                          beno
                            Have had a problem with my 07 D4D with the injector rattle as well as increased fuel consumption (approx 15% higher than when new) and has now cut out 4 times since new, first time when near new (now done 78,000kms).
                            After numerous attempts by local dealer to find problem (they did ecu update which quietened engine for a short period but has cut out again since & rattles badly again) finally decided to take to another dealer today and found problem with injectors, Toyota have authorised fitment of 4 new injectors which will hopefully fix the problem & restore my faith in the Toyota product, will update post when verdict is known.
                              Just had mine go in for the 50,000km service and has now done 25,000km since injectors were replaced with only an increase in fuel economy to show for its problems.
                              I still think the noise is there, however it is no where near as bad as before the injector replacement. I think I need to have a ride in a D4D that has not had the problem to put my mind at ease.
                              Might go and test drive a 2009 model and wait for the end of model run out bargains!!!!!!!!
                              Babs
                              2011 VX D4D
                                Rick
                                Rick
                                Hi Guys,
                                Got the call from Toyota Dealer... Injectors to be replaced! My faith in Toyota on the way to returning! ..obviously will wait to see results, but so far very relieved to know i dont have to "battle the hun" in order for Toyota to agree there IS an issue.
                                Watch this space!
                                Rick
