So recently oldgreyfart has had some major issues. It appears he has been well educated here on pp & done the right things. Probably just trusted a workshop a little too much. There is many stories I can share like this.
I'm getting in trouble with a few of you guys for being a bit harsh on some of these places, but it really is widespread.
I really want to warn you about this, to help prevent major problems as ogf is having, like many others.
Most of this is preventable!
I share with you what I can, I have a very interesting one this week.
To be clear, I work alone, I have the tools, knowledge, expertise & time to do the job right.
I have never had a "comeback" injector job, till now. So yes it can happen to me.
The BDG injectors & BDG seats/sheets were professionally installed at 103k, early last year.
The vehicle is an 2008, which had revised seats & no blow by at 103k.
So client calls a few days ago, tells me about some smoke on start up. She's on 122k now.
The smoke only happened twice. After a long trip, after the vehicle sat all day.
So we discuss options & I'm keen to check it out. We discussed it being ok & probably not what we both think it may be, you see it would be a first & very unusual. We were maybe going to do a few other little tune up items.
You see it's just been serviced 120k, the oil pickup is ok
??? but you know I don't trust many to do much, even check oil pickup correctly, as we have seen with ogf, not a good result.
I would trust all you people reading this to check it better than many workshops![](https://www.pradopoint.com.au/core/images/smilies/icon_wink.gif)
My client was told the oil pick up was ok.
Now if I get any of my facts wrong, I will edit to be sure this is the real deal.
Step 1 full diagnostic, injectors look ok.
Step 2 drop out new oil, could be a waste.............
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/8B6CEC61-F709-4B87-B40C-61B6917547A3.jpg)
Hole cow batman! Myself & BDG (Matt) are equally surprised at this.
All cleaned up prepared for removal.
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/F53F091F-2088-4440-8BAA-952BD0C6BE68.jpg)
Fuel lines removed, common rail & lines capped.
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/578CB2AD-3341-432E-8C5E-CA7E5CAF8D16.jpg)
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/9994AEC0-3455-4B29-B6C8-ED8888D53E10.jpg)
It takes time to take care.
Injectors capped as soon as cover is removed.
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/72A18EDB-7240-41CA-B94F-396A1B45A9DF.jpg)
Return side capped.
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/9BDFD359-40C9-41C7-8DFE-DCC50FBBACB4.jpg)
Injectors out
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/4029B8F7-1EC4-41C3-9DE3-43A4B71EB4C0.jpg)
Port 1 with blow by
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/32A0CA3E-D6A1-4C0C-A16B-98E691B6B87C.jpg)
19,000k
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/02B1D5CD-A94A-4727-9A99-F2A5862DBCDE.jpg)
I can tell you this has been leaking since it went in.
Quite a bit blown out of the BDG sheet/washer. Worst I have seen, I think.
![](http://i491.photobucket.com/albums/rr277/Robanth/injectors%20egr/EBCF5173-D56A-49B4-9C47-2589015E73F3.jpg)
THE BIG MESSAGE IS CHECK THE OIL PICKUP EVERY SERVICE 5000k.
Regardless of what Type of seats were used.
More to come, watch this 1# post
Return side capped.
Injectors out
Port 1 with blow by
19,000k
