Anyone out there using a Steinbauer chip on a standard '08 D4D, does it actually give you the 150Kw with standard equipment ie. exhaust? I got a bit confussed with some of the other posts with the DP or DT chips with the owners saying they had to use a lesser tune on the 1-10 scale because the heat issue to the dump pipe, does that mean you can get approx. 150Kw only when you have an upgraded exhaust system?
Did you also get the switch or remote control to turn the device ON/OFF? Is it worth it?
Any comments? Sorry, I was sure if I should have pin'ed this question onto KJH's thread "Power Chip".
Nick
Nick
