Upgraded Turbo? Anyone?
  • Upgraded Turbo? Anyone?
    Just wanted to know if anyone had upgraded or is thinking about upgrading their turbo chargers?
    Any ideas? Previous experiences? I've got about 7 different turbo's in the garage ranging from WRX STi Ball Bearing to T88 Garrett units. I know these might be a bit too BIG but this is my first turbo diesel and I wanted to know if a bigger turbo will help make it go a bit better?
    Oscar
    [b][color=#0000FF][size=7]Silver '05 Prado VX 3L TD[/size][/color][/b]
    [color=#FFBF00]G[/color][color=#0000FF]O[/color] [color=#FFBF00]P[/color][color=#0000FF]A[/color][color=#FFBF00]R[/color][color=#0000FF]R[/color][color=#FFBF00]A[/color][color=#0000FF]![/color]
    Re: Upgraded Turbo? Anyone?
    The 1kz factory turbo is a ct20 and is tiny... this is for good low down performance and a turbo diesel is a low reving motor. As such a small turbo is not always a bad thing, it gives good low down performance and good throttle response.
    By fitting a bigger turbo/High flowing you are most likely going to lose bottom end performance (more lag) and gain at the top end. This is ok on an out and out performance vehicle were peak power is the point, not where in the rev range it is.
    For a vehicle like the Prado you are probably going to want a more of road/ street usable power torque curve... good bottom end and midrange... where you do most of your driving.
    A slightly bigger turbo may suit your wants (I think a T88 might be to big though ...arn't they good for like 400+ KW :?: ... it'd just come on boost and you'd run out of revs :wink: ) Same with the STI turbo, it must be must be good for 200kw +.
    A ball bearing turbo in the same size (as CT20) or slightly bigger would probably be the go if yor really wanted to go this route as ball bearing turbos giving better boost response.
    I'd suggest you stick with your current turbo and try a boost controller. Lift the boost a few PSI and see if you are happy with it. Combined with your exhaust and Dtronic you should have a reasonable result.
    You can still go the updated turbo route down the track if you're still looking for more.
    Just remember the 1kz is a primative engine by todays standards. It can trace it's roots back to the mid/early 1980's. Yes it has EFI but underneath is still a motor that should be running a water pump in a mine not a modern vehicle... it's a reliable chugger not a traffic light racer.
    If you do go the turbo replacement route you will certainly have an interesting project on your hands....
    Mick
      reviving one from the dead here.
      specs on the toyota turbos are hard to find ,
      I know the 1KZ turbo is a CT20 just looking at comparisons with the CT26 and Garrett TO3 as a direct replacement for the CT20.
      Any opinions??
        Or has anybody have a picture of the exhaust housing of a CT20 turbo ???
          5le engine upgrade for prado 120
          i want to increase the torque and speed any ideas? it feels under powered driving on the egyptian sahara sand.
          the egyptian
            Reviving an old thread here... But I removed the turbo on MUMSRIG yesterday and will be sending it away for a rebuild and Hi Flowing.. Will inform if there are any noticeable differences once it's refitted..
            Mitch
              Guys a while back I spoke to Graeme who makes the Gturbos in Perth. Now for the cruiser's I know he has been getting some stupid hp numbers!
              He also does an exchange basis on the 1KD-FTV turbos...
              Here is an email from him from back in Feb...
              "Hi Chris,
              Finally I have some test results - better than expected. No chip/tuning done, just swapped perfect factory turbo for my upgraded factory turbo. On both graphs the bottom lines is the boost - it is slightly higher with my turbo even without tune. Red is factory, green is Gturbo.
              More power with same fuel = better economy.
              After tuning, even without raising boost pressure, power will rise to 146hp based on te air fuel ratio results - very exciting.
              After raising boost pressure and tune to factory air fuel ratios, power will rise to comfortably over 200hp at wheels which was the design design brief.
              I hope the dyno is informative - kindly provided by suprised a Qld customer.
              Best regards,
              Graeme Bentink
              GTurbo Pty Ltd
              Ph: 0401 524 399"
              [SIZE=1]2013 D4D Auto Crystal Pearl "Altitude" - Caloffroad Bilstein 3 inch lift, SPC UCA's, diff drop & sway bar ext. FJ Rims-ET15 285/70R17 Cooper ST Maxx. ARB deluxe colour coded bar. Lightforce 240 XGT's. Modified X9 winch, 6hp motor & 30m 10mm rope. Dual Batteries, Redarc-SBI212, Mk3 diode & custom wiring. Water watch. ARB compressor. Twine underbonnet shower. Scangauge II. Custom rear draws. TG150. Tectyle rust protection. GME 3600 UHF, AE4705 antenna. PWR ATF cooler. Genuine tow bar.[/SIZE]
                Do you have the Dyno Graph Chris? What is so special about his turbo's to get these gains?
                  Never mind... I found their facebook page and have sent a message
                    I'm looking forward to the results as I'm in the market for an upgraded intercooler and/or turbo.
                    95 3.0 Camp Car, 150 V6 Daily Driver[SIZE=4]
                    [/SIZE]
                      http://hpdiesel.com.au/toyota-hilux/...nt-intercooler
                        I've been looking at these as I'm not sure if the factory intercooler will allow me to get the best from a turbo upgrade. I'm just not sure if it will fit my 90 series. Has anyone fitted one of these?
                        [/SIZE]
                          Bumping this one back to the top. Over the past three years has anyone experimented here? I have just bought a boost gauge and boost controller and will have a little play (within reason). Exhaust will be next then perhaps a chip. I have seen GTurbos but very expensive (around $3500 + tune). Thought I'd poke and see what has proven itself!
                          [B]robe0455[/B] 2002 KZJ95 Prado - Bilstein/TJM 2" Lift, Glen_EP Front Disconnects, D697's, Platform Rack, TJM Roof Top Tent, Snorkel, HID's, Sliders, Underbody Protection, Dual Batteries, Boost Mods, Catch Can, Gauges and some other bits and bobs...
                          [URL="http://www.pradopoint.com/showthread.php?38366-Mar-s-95-Series"][U]*Build Up[/U][/URL]
                            I'd like to give it a go when I find some time. I'm sure there are some easy gains to be had but requires setting up some datalogging etc first up. Probably one mod that is guaranteed is a larger dump pipe to aid spool.
