Poor Fuel Economy from 2008 D4D
    Re: Poor Fuel Economy from 2008 D4D
    M 2008 D4D 46,000 km started to show poorer economy. I removed the air flow sensor near the air filter, and gave it a bit of a gentle clean by gently blowing off the minute amount of dust in it and its going much better.
    More grunt down low and more km per fill. Currently sitting on 800 km at half full after 100 km of low range work at Abercrombie. Not too bad IMO.
    Greg - 08 D4D Prado,
      Corigator, you might be on to something. Toyota have it in there schedule to glow the sensor clean every 60 000km.
        Do you mean Blow the sensor clean? If not what do you mean by glow?
        [b]2013 GXL LC200 TTV8[/b]
        TJM Alloy Bullbar
        Towing a Jayco Expanda 17.56-2OB
          Yes, blow it clean. Early morning typo.
            Sorry guys....where about is this sensor located?
              air flow meters (AFM) are normally located somewhere near the intake pass the air filter. What it does it measures the amount of air flowing into the turbo (if turbo diesel) or straight into the mainfold. The on board computer (ECU) will then assign appropriate amount of fuel/ignition timing etc to make everything work....this is in simple terms.
              If you look at your airbox, you'll find some wires hanging off it...or it might be on the rubber tube near the airbox (can't remember) look for wires and you'll find it. Generally these sensors are very fregile so be careful with it. Gentle blowing is fine and so is using an electronic contact cleaner (dick smith have them).
                hey guys just reading your comments about poor fuel economy.
                l brought my 06 diesel auto its not a d4d with 120 on clock was getting nearly 900km before second tank kicked in and then getting up to 1350 before nearly empty mark on second tank.
                l got it serviced and have added a roof rack and snorkel and rack lights now l get 600km then the second tank kicks in and around 1000 at empty on second....
                was stressing me out could not loose that much l might have to check the air filter thing would adding a dp chip help manage the fuel consumption better or worse ???
                thanks corallen
                06 GXL 3.0LT TURBO,50 mm ride pro lift, poly bags,arb roof rack with 4x ipf 800xs driving lights,arb awning,gme radio,red arch dual battery with pirhana batt monitor,2x ipf 800xs driving lights on soverign bar,mickey thompson ATZ, kaymar rear wheel spacer,tinted windows,red arch electric brake controller,diffx2 transfer case and gear box breathers just fitted front and rear recovery points.
                  thanks corallen
                  Yeah sound like there is something a bit off there cause if i use your figures and base it over 170 litres (casue no matter how empty i run it when i fill up there always seems to be 10 to 15 litres slopping around in there somewhere)
                  You have gone from 12 to 17 litres per 100k if you went only to 14 i would say welcome to the world of acessories but your jump seems to be to large. Even if you fit a DP chip and get the claimed 10% better fuel economy you are still in the high 15's which seems like a lot
                  Dont list all ya mods, you will only be more upset when i get further
                    thanks corallen
                    yeah it is wierd l tried to blow out the plug near the air box but could not get to it so will wait till l get an air gun but it is really strange my father inlaw gets better economy in his 94 80 series that is loaded to the max need to find out if there is a switched on diesel merchanic in the west who knows what to look for any ideas????
                    thanks chester
                      Mate i am doing an economy run for you at the moment so you have some comparison. The only other non engine one i can think of if it is a manual are you getting some clutch slippage or something that is causing to rev higher. but to put it in perspective for you i get about 1250k around town and that is with the following
                      Suspension lift
                      second battery
                      BFG 265/65/17
                      ARB bar
                      Heavy duty racks with bike carriers
                      I will let you know how i go oh and i do run caltex vortex diesel that seems to get me further but i am more inclinded to think this is beacuse it foams less so i literally get more in the tank before i loose patientce than i used to, rather than fuel quality
                        thanks for that cheste....
                        yeah l have an auto 4 speed. plus heavy roof rack and mickey atz plus an awning and 4 ipf spotlights on the roof rack.
                        l use bp fuel and notice it is very foamy tied to trickle fill but impatient people waiting will try it this weekend.
                        l dont reackon the rack and lights would have lost me nearly 400 km from the 2 tanks l was getting nearly 1400 when l first got it just doing my head so looking for a good merchanic to have a look and maybe a tune...
                          If it is an auto maybe get the tourque converter looked at as well as irt may not be locking up
                          Also as the micky t are 265/70 /17 is your speedo right or maybe it is out causing the K to read wrong
                          • #28
                            yeah torque converter might be the go it is having hassles with gear changing sluggish and this happened before l got the mickey and we have a speedo check near us and mine is 4 km fast than than the speed trap so speedo 104 trap 100 it is wierd alot of people here have it happen after a service like me something so fine must be changed or bumped to do this
                            thanks corallen
                            • #29
                              Ok mate the story so far
                              1125k completed
                              Quarter of a tank remaning
                              All city driving
                              100k towing the van
                              Prado with acessories on and fridge ext inside weighs at the tip 2490kgs :shock: fat bastard
                              Economy so far 13.9l per 100
                              • #30
                                1125k completed
                                All city driving
                                100k towing the van
                                l am still going on mine into the second tank just at three quarters of second tank and speedo on 810 km does the prado have a warning fuel light and how much would be left???
