12 months ago (275000KM) I had the injectors replaced and the inlet manifold cleaned. About 4 months later the engine starting missing under load between 2000 and 2500 rpm only. I have since had the suction control valve and EGR replaced. Although the condition has improved it still happens intermittently, but always under load ie going up a hill. It is most prevalent when at constant speed. I have observed it only occurs when the engine is at operating temperature. Now at 305000km. Any ideas?
1KD Engine has intermittent missing between 2000 and 2500 rpm
HI Rodney, I recently had a a total engine refusal to start after a history of missing at highway speeds, the RPM you mention. Seems the culprit is the Injector Control Module slowly dying. Mine is now dead. This is according to my mechanic. I am still waiting to have this confirmed as I cannot find a replacement module. Will try a reset on monday - shorting pins 4 and 13 on the ODB with ign on and see if that resets it. No help to you maybe but of interest and possibly something to look out for.
