Hi to all this is my first post here and I have an issue with oil/oil pressure my2006 grande purchased 3weeks ago 210kms been running well had bull bar fitted dual battery's,40mm lift,wired up fridge,lights etc and changed engine oil using 10w30.Just got the thing how I wanted headed away ova weekend towing my 16ft pop top towed there fine in 4th gear no issues what so Eva.On way home had been going for 30 mins in 5th was doing it easy as pulled ova at a tourist attraction and the oil pressure light flashed at me twice give it a slight rev and it went out so I checked level and it was fine (still about 5mm over full as per when was serviced) never thought much of it went in did our thing and came out started eng sounded fine no light so we continued on about 45mins later the light flickers again a few times and came on while driving along I figured it must have a dodgy sender so at the next safe place to stop I pulled ova and got out to check again (slight rev never made light go out like last time) I got out and it sounded like it had slight rattle in it so I shut it off while I pondered on the issue for 5 mins I rechecked oil etc all ok and thought I would start it again and see what happened as I figured the damage was already done it started and light went out as normal it made a slight rattle as it did and sounded normal again with no light on so I decided to continue on taking it easy towing in 4th again and doing 100kph at 2500rpm no more light and towed to home ok (80kms and about an hour further up the road) when we got home it sounded ok no rattles but a slight wine/wuring noise stoped engine and restarted normal again!!!
any suggestions/experiences ideas muchly appreciated please
