Engine movement flex (Engine mount)
  • Engine movement flex (Engine mount)
    I've been noticing the manual transfer case lever moving a lot while driving. Especially when the engine is under load. eg. Towing a trailer.
    I popped the bonnet and took a video of the engine under a load test. That is foot on the break and accelerator at the same time.
    The video shows what looks like to me a lot of engine movement in the engine bay.
    (sorry couldn't upload the video)
    (I took a screen capture of no load then load of the video. 2 Images attached)
    It seems the engine is moving around 3-4 cms
    Is this symptomatic of an engine mount worn or failure?
    If so what are people's experience with replacing these. (Easy, Moderate, Hard, Workshop only)
    That's a lot of movement, could be either broken bracket
    or rubber mount.
      There have been reports that the engine mounts on the V6 can collapse into the chassis rail. So it is likely that is what has happened to yours.
        Ok so a quick look online says this is a suitable replacement part:
        (assuming the bracket hasn't snapped/corroded off the chassis)
        Febest TM-120 FRONT ENGINE MOUNT (HYDRO)
        Model: TOYOTA LAND CRUISER PRADO 120 GRJ12#/KDJ12#/RZJ12#/TRJ12#/VZJ12# 2002-2009 OEM: 12361-30050, 12361-30051
        Suitable for the following vehicles:
        Approx $90 each
        Are these a hard thing to replace?
        thisavros
        Lurker
          Sorry
          I have since found the correct part is a TM-034
          Febest TM-034 FRONT ENGINE MOUNT (HYDRO) Model:
          OEM: 12361-31080
          Ill know for sure as Im getting them fitted this week.
            Check out this link http://www.pradopoint.com/showthread...dder-vibration
            I had a problem outlined starting in post #36
            All good after replacing mounts
            Pedro
            2007 D4D Auto
              Can anyone tell me how much to replace both engine mounts? I have a mate who's been told he should replace both at next service ( 2008 D4D but should be the same as the petrol.)
              craigm
              Addicted PP Member
