Re: LPG Conversions
this comes from the cylinder install manual for my liquid injection install. 2004 prado (late 2004 with 5 speed box)
Petrol Gauge Wiring Modification
1. Cut off wiring from sub tank. Install 50 ohm resistor between brown and yel/black wires and insulate.
2. Join the two white/black wires (next to each other) and insulate.
3. connect the remaining white/black (between the brown and yel/black to ground (earth).
90l light will always be on and fuel gauge works only from front tank.
If i ever pull the dash out i will get rid of the 90l light aswell.
