Sump Plug issue - leaking
  • Sump Plug issue - leaking
    Hi All,
    My Prado is leaving drops on the ground where I park it.. I'm guessing about 5 drops per hour.
    see attached pic. I think I see the issue.. there is a definite V groove in the washer/gasket.. and you can see that they have used gasket good or similar to seal it up..
    questions...
    - is this V groove normally there.? I don't think it would be. Looks like they have hit it with a screw driver or something trying to get it off, haven't been able to and as such have bogged it up with Gasket Goo etc... anyone agree with my thoughts on that..?
    - is it normal to use silicone sealer/gasket goo etc.. I've changed many oils on motorbikes and from memory I never used sealers.. just nipped it up and all good.. ?
    - I just looked at it again before posting.. I think they did it up with a rattle gun, too tight and have cracked the washer/gasket.. that's how it looks to my forensic brain now.. any takers on that conclusion..? it was BLOODY hard to do.. I would think these don't need to be done up with a rattle gun..?
    and lastly.. I'm not too stupid but - this is the engine sump right?, not centre diff etc etc.. I can't be buggered jumping under the car again, not much room there!
    appreciate any other ideas/thoughts on the picture and issue... it's boxing day now but on Monday I'll be back to my new service centre asking them to fix it! - this issue has only occurred since I went to them.
    Thanks all!
    Re: Sump Plug issue - leaking
    Hi Kiv7,
    Quite a mess you have there! who butchered that? a Toyota franchise or do you get your services done else where?
    Have you loosened the plug to take the pics? as it's obviously not in all the way, also the washer almost looks like it’s made from insertion rubber not the fibre style gaskets Toyota supply.
    At the very least you need a new gasket (Only a few $ for a pack of 10 from Toyota). The plug should only be nipped up (best to use a torque wrench) and no sealant is necessary.
    Never use a rattle gun and yes that’s the engine sump.
    Mick
      Thanks Mick!
        No worries, I hope it's as simple as a gasket.
        You can buy genuine ones online here (if you don't have a dealer near you):
        Ebay ad for sump plug washers
        If there is damage to the plug,seat or thread then you may be up for some further repairs or parts.
        Mick
