was wondering is there any differance in an toyota windscreen and an after market one????
prob price but anything else
thanks
06 GXL 3.0LT TURBO,50 mm ride pro lift, poly bags,arb roof rack with 4x ipf 800xs driving lights,arb awning,gme radio,red arch dual battery with pirhana batt monitor,2x ipf 800xs driving lights on soverign bar,mickey thompson ATZ, kaymar rear wheel spacer,tinted windows,red arch electric brake controller,diffx2 transfer case and gear box breathers just fitted front and rear recovery points.
I had after market fitted to the old 95 series by windscreen obriens and was better then the factory one, was tinted plus also had the dark band accross the top, there all laminated and wouldnt be surprised if there all made by pilkiton glass anyway ?? (except when originally from Japan) The only thing I did at the same time was replace the rubber seal that went around mine as the old one started looking a bit shabby but I bought genuine for that as I dont like the one they use, not moulded correctly and end up lifting in the corners but that was on the 95 series, looks like the one on the 120 series only runs across the top of the screen not down the sides. The sides are covered with the bigger plastic bits. Just make sure when they cut the old one out that they dont cut through the paint where they put the sikaflex, otherwise you will end up with rust, if they happen to do it they do have some stuff they put on the bare metal, but possibly if your not watching they might not bother with it. Nothing worse then some one watching over your shoulder while working but after some of the bodgy stuff I have had done I dont care, Ill watch from start to finish to make sure its write, shame I wont be able to do that when they replace the brackets on the bullbar as your not allowed in toyota workshops OH&s issues..Dont have glass insurance on your policy do you ?? wont cost you a cent if you do Regards Steve
My first Prado, 2005 model, the factory windscreen was absolutely crap. I only had to look at it and it would scratch, i actually wondered whether it was even glass it was that soft, i thought maybe they had gone plastic windscreens. Anyway before i hassled toyota about it a truck chucked up a rock and cracked it. The after market replacement was much better.
No problems with my current 2009 model though, other than the small crack from some tosser chucking up stones as he passed me at 100MPH travelling up the Cape :evil:
In Melbourne national windscreens $180 fitted. Looks the same quality as obrians but does not have blue dimming at the top.
did i read on here somewhere about different windscreens for petrol and d4d? Something about noise?
Yep there was a thread about a year ago that covered this. Apparently the diesel ones are a bit thicker for noise insulation.
No. the diesel and petrol windscreens are exactly the same. The cost of tooling and production of different windscreens for different engine fits (for just a windscreen) would be prohibitive.
Some aftermarket glass manufacturers are better than others. There used to be at least one "aftermarket" manufacturer in Oz that also made OEM glass for all the big manufacturers. In fact, that manufacturer has been in business for almost two hundred years (before cars) and pioneered (and patented) some great advances in both automotive and domestic glass production. All automotive glass in the world uses glass made by one of these creations (float glass).
All autoglass sold in Oz has to meet the applicable standard. Generally, the only differences you'll find are long-term, such as the tendency to de-laminate (one QLD manufacturer was famous for this in the 80's). Or for glass to go "milky" around the edge - caused by moisture ingress via the interlayer.
[i]I remember when sex was safe, and flying was dangerous![/i]
I had my Windscreen replaced on my 08' Model D4D only about 5 weeks ago.
O'Briens did mine and I was told that with them, you loose the Original Toyota Seal, that goes around the Windscreen.
O'Briens don't replace the seal at all, instead they just apply a thickish corking compound to stick the windscreen to the Body.
I have noted that since fitting that the Vehicle Fogs up quicker that before from the bottom, which means I am always having to
turn on & off the Front Demister.
As for $$$, O'Briens was about $600 fitted for memory.
Stuart
Stuart Trevena
[COLOR="#FF0000"][B]2008 Prado GXL D4D 3.0L T/D 5 Speed Auto Colour: Dune with loads of Extras[/B][/COLOR][COLOR="#0000CD"] [B]and 2015 Tvan MK4 Murranji Offroad Camper[/B][/COLOR]
Hi Stuart, not sure if you have the option or not but check if your insurance does glass breakage covering any window in your car. I have it on my wifes car and my prado, roughly $70 added to the comprehensive insurance policy, well worth it. I have used it twice now on both cars. both repairs done by windscreen Obriens no issues. Regards Steve
Originally posted by PradoGXL08
Hi All,
As my insurance is done by my Father (as he does all our Private Family vehicles and House) through a Broker, I was told that option wasn't taken up by us,
for some strange reason, as he normally has it included in all our policies.
Stuart
Stuart Trevena
Hi John, i just found the Thread about the different windscreens i was refering to.
Geoff
Did you know that your D4D Prado has a special noise-reducing windscreen? Most auto glass replacement people don't.
The genuineToyota part number for a standard windscreen for a petrol 120 series built around June 2007 is 5611160471, priced at $860.00
The noise cancelling one for the D4D is 5611160650, priced at $950.00.
I just had my windscreen replaced a few days ago. One of my mates, a D4D owner, contacted me. He was getting quotes for a replacement windscreen from the same people I used. They didn't know about the two screens and refused to believe him when he told them. He obtained the part numbers from Toyota and told the glass people. After a long period of silence they called him back and said he was right.
So now you know.
How many D4D Prados have had the wrong replacement windscreens fitted?
I've just had mine replaced. I asked for a genuine Toyota part but was never asked whether it was for a diesel or petrol Prado, or for a VIN which determines the requirement. My insurance company paid $860.00 - the wrong price for the windscreen appropriate for my D4D Prado.
