winch cradle
    Just wondering does this winch cradle fit to the bull bar or the chassis as want to fit winch to ARB non winch bar
    Cheers Adam
      Cheers Adam
      Hi Adam
      The cradle is sandwiched between the mounts and the bullbar, each bullbar uses its own mount, so I would seriously doubt if it would fit the ARB. If you find a friendly dealer (good luck!!) they may have one of the old style cradles lying around after the mount recall they could throw in the back of your car instead of the bin, might be able to modify it to suit the ARB. Nothing a grinder, a welder and a PP tech day couldn't fix!!!
      Matt
      waltec
        Thanks watec,
        will now have to make some calls at least it will give me some where to start
        Adam
          Prado winch cradle
          Hi guys I need some help.
          I am trying to get hold of a winch cradle for a 06 prado alloy bullbar. I guess most probably know Toyota don't supply these any more which is just amazing. I have tried a few Toyota wreckers on the net without any success.
          If anybody can suggest another source or has access to one I would greatly appreciate it.
          Leigh
            I would have thought they would still be available due to the bull bar mounting
            upgrade going on?
            Another option is Tigerz winches, they have a universal mount that you could proberly adapt.
            LeighW
              I might have one available soon. But from memory, they are about $430 from Toyota and are available as Leigh said.
                Thanks guys but I have spoke to a few dealers and they all say the same a discontinued item and nobody has one listed in their stock.
                Amts I would be more than happy to purchase if you have one retail is $250 from Toyota.
                Leigh
                  The part number you want for the new winch cradle is PZQ29602WC. Mine doesn't have the extra brackets between the winch cradle to the bullbar mounts. That's why it is getting replaced. You are better off contacting your dealer and get the whole kit off them. I can find out the price from my usual spare parts guy and you can quote that price to your local dealer if you like.
                    I sure they would be still available, I think this has been covered before, from
                    memory the confusion is over the part numbers, they need to search on the new
                    winch plate for the new bull bar mounts and not the old one.
                    Check that they are searching for the correct item.
                    Leigh
                      Originally posted by LeighW View Post
                      I think this has been covered before, from memory the confusion is over the part numbers, they need to search on the new winch plate for the new bull bar mounts and not the old one.
                      Correct. See here http://www.pradopoint.com/showthread...l=1#post301698
                      I'm waiting for the kit myself as the dealer who did the recall didn't do it properly.
                        Just called my dealer and gave them that parts number heaps in stock but he's not sure if it's the hole cradle kit hopefully I will have a call back this afternoon.
                        Many thanks amts
                        Leigh
                          Definitely a kit. (Trade) Price should be $201.30 inc GST.
                          amts
                          Ninja Poster.
                          • #28
                            I can't thank you guys enough I picked up my cradle today normal $239 sold to me for $200 as I taught them something about their system. Winch to be fitted in a cupple weeks.
                            So once again thanks
                            Leigh
                            • #29
                              Good stuff!
                              • #30
                                Does the cradle bolt to car chassie or soverign bar?
                                Sent from my GT-I9000T using Tapatalk
