Loss of cruise contol when engaged
  • Loss of cruise contol when engaged
    While dirving at 60ks in cruise control, cruise control disengaged with out any help from me. Has this occurred to any other 06 Prado 3 litre turbo diesel
    I find problem when i resume sometimes it works sometime it won't.
    The book says that once you drop below 40kph it will lose the setting.
    It also won't work below that speed.
    2006 TD Grande
    ARB Winch Bar. Rallye 4000's
    GME TX 3400
    BF Goodrich 265/65/17
      The 40kph cut off is pretty standard with all cruise controls, this has been the same in my commodores and falcons.
      Pradopoint GTG website:
      My Weather Station In Alice
      My photo website:
        Yep mav, same in alot of my other cars.
        But like i said sometimes it will resume without dropping below that 40kph and sometimes it don't.
        I am not sure if it has a certain time also before it won't resume.
        2006 TD Grande
        GME TX 3400
          That sounds like a definite fault and I would get it checked under warranty. The CC should always resume its set sped when the resume button is pressed so long as the car is travelling above the 40kph threshold.
          My photo website:
            Mine does the same,
            Every now and then it decides NOT to resume when you hit the lever back up.???
            Did a 1300klm trip last week and it did it about 6 times all told.
            Mitch
              cruise drop out
              What trans type is happening to? Man or auto ? Manual will drop out if you are going up hill and your speed drops by 12 kmh it will drop out.I use mine every day in my manual and have never had a problem.
              Warby 8)
              2005 GXL V6 petrol six speed manual Charcoal grey
              Factory Bull Bar
              Factory towbar
              Tinted windows
              Bonet, headlight protectors
              Grill cover
              Weather sheilds
              GME Tx3400 UHF
              Cibie Super Oscars
              Bfg,S (as they replaced the grand crappers 30k)
              Camelgroup camper trailer (beach comber off road)
              Gr8 wife (louise)
              Feral dog (ridgie)
              and the gr8 outdoors what more could you ask for
              WISH LIST
              Black widow drawer unit or alike
              snorkel
                Cruise Control Disengaging
                Cruise Control disengaging at 60 kph. This occured when cruising , not slowing down below 40kph. This has occured on my 2006 Prado 3 litre diesel
                  How far below your set speed is this 60km/h? As Warby said, bear in mind the cruise control will quit if your actual speed falls too far below your set speed, if you are going up a hill in 6th for example. From memory the tolerance is quite narrow on the Toyota.
                  Drew.
                    Mine is Auto not sure how far i drop in speed before it sometimes doesn't resume.
                    I just know that it has done this when i don't drop belw 40kph.
                    So you could be right, might have something to do with dropping to far below set speed.
                    2006 TD Grande
                    GME TX 3400
                      Re: cruise drop out
                      Warby 8)
                      Yep that is generally the two criteria for disengagement of the cruise function. Below 40kph and if speed drops below set speed by more than 12 kph.
                      My photo website:
                        I have the same issue. You can cancel the cruise control as you approach a roundabout (for example), get past the roundabout (whether you get below 40kph or not) hit resume (above 40kph) and sometimes it will re-engage sometimes it doesn't.
                        Sometimes you can cancel cruise control as you approach a red light (so you drop below 40ph) and sometimes when you hit resume (always above 40kph) it will work and sometimes it doesn't.
                        So I too will be taking this up with my dealer in the near future.
                        2006 D4D VX, Diesel, 5-speed Auto, Charcoal, dark window tint, Toyota hitch receiver, custom home-built drawers, Piranha Fridge slide, Waeco 50L fridge, Dual Battery, Polaris GPS and Reversing camera
                          If you get below a certain speed then it will cancel the original set speed. I'm not sure what the speed is that it cancels itself out at, but I know everytime I stop or get below a certain speed (maybe 20-30k's) I then can't resume.!
                          03 Grande V6 4.0L, ARB Deluxe winch bar, XD 9000 Warn winch, Pacemaker Headers, Colour Coded Safari Snorkel, K&N Airfilter, Slotted RDA rotors, 55W HID Hella Rallye 4000 spotlights, Dual batt, TJM comp, TJM underbelly bashplate and custom stainless front bashplates, Extended diff breathers, Reverse camera (Eclipse), Yokohama AT-S, ICON 2.5 adjustable remote resi coilovers(front) ICON 2.5 piggyback shocks(rear), 2" lift airbags, Icom ic400pro, Engel 40L, Custom drawer system, Stainless recovery points, Kimberley MyCube rooftop camper.
                            The minimum speed is 40 kph.
                            LES
                            [url=http://www.brisbane4wdclub.org/index1.htm]Brisbane 4Wd Club Inc[/url]
                            [url=http://www.brisbane4wdclub.org/images/avatars/mystuff.htm]MY STUFF[/url]
                              Yup minimum speed for being able to activate the cruise control is 40kph. However you cant resume the original set cruise speed even over 40 if the speed at any point drops under a certain speed.! I'll check it out tomorrow but I know for sure if I stop at a red light and then get back upto speed I cant resume the cruise. I've got a feeling anything under 20-30k cancels any settings.
