Belt slipping and squeeling like pig
  • Belt slipping and squeeling like pig
    Well since its started to warm up here a bit we put the AC on for the first time in a while and the thing squeeled like a pig.
    I popped the bonnet and could see the belt slipping on the AC compressor pulley.
    I guess my question is, should I just replace the belt or can the tension be tightened to stop it?
    Andrew
    2005 VX Diesel - [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12823"]My Rig Buildup[/URL]
    [URL="http://www.fuelly.com/smallsig-metric/65233.png"][img]http://www.fuelly.com/smallsig-metric/65233.png[/URL][/img]
    [B]Bitumen - A blantant waste of taxpayers money![/B]
    [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12197&start=0&st=0&sk=t&sd=d"][/URL]
    When I had my 2005 Prado with the 1kz; the air-con belt was always a source of annoyance, it started slipping at 10,000k and I always seemed to need to tighten it a lot more than I expected in order to stop the slipping.
    If the belt looks ok and the pulleys aren't worn then I would suggest tightening it a bit.
      I remember a thread earlier this year where the issue was solved with some kind of Spray on the belt. However, if the belt is slipping that badly perhaps either adjustment or replacement will be the go.
      http://www.youtube.com/watch?v=LqFDMC5jqFE or http://www.supercheapauto.com.au/onl...91#Description
      craigm
      Addicted PP Member
        I apologise in advance VX, but I read the title and had to have a cheeky look see.
        I slip my belt off and she laughs, unless I'm dreaming and then she squeals like a pig
          good one, I can always count on you for a laugh
          Andrew
            I've tried to tighten the pully and can't seem to get it much tighter, but its still squeeling. Might have to buy a new belt I think
            Andrew
              Be careful with spray on belt grip. If it gets into the bearings then you'll know what squealing is.
              [SIZE=1]Cheers Jim.
              [/SIZE][COLOR=#0000cd]
                Thanks Ozpat I don't plan on using any of that
                Andrew
                  you can hold a bar of soap on it and stop the squealing....does not take much. The belt was quoted to me on my last service for $103. I'll probably buy one a bit later, no rush with these new belts. They don't exactly snap like old belts used too.
                  _______________________________________
                  [SIZE=1][B]2011 Silver 150 DVD[/B] [B]GXL[/B][/SIZE][SIZE=1], Safari Snorkel, Sand Grabba mats, Michelle Sacs seat organizer, ARB Bull Bar, Lightforce 170 HID, Bonnet and Headlight protectors, Dual Batteries, Engel Fridge, Kaymar rear spacer, Cooper STTs [B]x 6[/B], Rhino Pioneer tray in black, MaxTrax, Black Widow Drawers with top shelf, divider & cargo barrier, ARB Sports Nitrochargers and springs, ICOM IC 440N CB
                  [/SIZE]
                    just b4 i went to cape york i had my belt replaced . 2 days after it was replaced it started to make noise at start up , but would quiet down after a couple of minutes ,i thought it would bed in . it got worse every day . after 7600km when i was REALLY over it my mechanic replaced it with a genuine toyota model . Quiet as a mouse ever since . this was after using all sorts of stuff to shut it up and including cleaning all the pulleys and replacing the pulley bearings . the dayco belt was replaced with a genuine toyota .
                      The soap idea I have heard of before.
                      I must say I had a blonde moment earlier today and didnt loosen the pulley bolt before trying to turn the pulley tensioning bolt. Hence once I banged my head against the wall I had a revelation that I wasnt doing it correctly (yeah the wife tells me all the time but hey I enjoy it ) so all I had to do was loosen the pulley bolt and then tighten the pulley and so far so good.
                      and for all those that care I am not actually blonde
                      Andrew
                        Thanks for the return laugh! :P
                        Give your wife my commiserations
                          I do every time mate ROFLMAO
                          Andrew
                            not sure if relevant but mine was also squealing (car that is) for some time, took it for service and he rang to say i lost a belt. I say what? there is a double belt (the low one i think) and i was missing one. Since then all good now I have two.
                            cheers,
                            [b]Toddy...[/b] [size=1][b]2006 GXL Prado[/b] : Silver : ARB Sahara Bar : EFS Elite Suspension : PolyAirs : Airtec Snorkel : ABR HID Spotlights : AMTS Bashplates : DIY Water tank : DIY Rear Drawers : DIY Fold down Table : GME TX3440 : ARB Dual Battery System : DIY rear sockets : DIY Washer Jet Upgrade : Tekonsha P3 : DIY Rear Diff Breather : radopoint Sticker (no P): Pink MaxTrax (Yes) :
                            [b]2010 Jimboomba Maddison Off Road CT[/b] : DIY 12V system : DIY Electric Water Pump :[/size]
                              well the belt snapped last week, so I replaced it. Now it has started squeeling again, my concern is that the reason it snapped last time was that it was too tight. It only squeels when under heavy load and changing gears ie taking off from lights or going up hills. From what I can tell its the AC pulley thats squeeling.
                              Any ideas? could it be someting wrong with the compressor gettting too tight and putting too much presuure on the belt?
                              Andrew
