Belt slipping and squeeling like pig
    Originally posted by blackvx View Post
    well the belt snapped last week, so I replaced it. Now it has started squeeling again, my concern is that the reason it snapped last time was that it was too tight. It only squeels when under heavy load and changing gears ie taking off from lights or going up hills. From what I can tell its the AC pulley thats squeeling.
    Any ideas? could it be someting wrong with the compressor gettting too tight and putting too much presuure on the belt?
    Have had a compressor bearing go on the pulley before.
    Sent from my GT-I9100 using Tapatalk
    _______________________________________
    [SIZE=1][B]2011 Silver 150 DVD[/B] [B]GXL[/B][/SIZE][SIZE=1], Safari Snorkel, Sand Grabba mats, Michelle Sacs seat organizer, ARB Bull Bar, Lightforce 170 HID, Bonnet and Headlight protectors, Dual Batteries, Engel Fridge, Kaymar rear spacer, Cooper STTs [B]x 6[/B], Rhino Pioneer tray in black, MaxTrax, Black Widow Drawers with top shelf, divider & cargo barrier, ARB Sports Nitrochargers and springs, ICOM IC 440N CB
    [/SIZE]
      If it only squeals with the aircon on I would check the compressor to make sure it is not
      seized.
      If it is ok then you may not have tensioned the belt enough when you installed, did you run
      it for awhile after installing and then rechecked the tension, if not then retension and try it again.
      If it still plays up then most likely either the alternator, tensioner or air conditioning compressor bearings
      are faulty or air con is over pressuring for some reason.
      LeighW
      LeighW
        Gday blackvx
        If none of the above stop the squeal also make sure that it is not the harmonic balancer! (Lower engine crank shaft pulley) There is a very thin rubber insert towards the inner part of the crank pulley that absorbs engine vibration. Draw a distinctive white line from the inner of the crank pulley to the outer edge of the pulley. (Front part as in where the center nut goes) Start the engine and rev it to make the belt squeal. Once you have made the belt squeal turn the engine off and check to see if the line on the front of the pulley still lines up. If the line is no longer lined up then your harmonic balancer (Lower engine crank shaft pulley) is worn!
        Providing that i have the correct part No:13470-31013
        http://www.toyotapartszone.com/oem/t...470-31013.html
          Having the same problem as Kav, had my belt replaced at 205,000km after it began shredding which I had a spare belt on board. Apparently it had the original belt on it so really did quite well. I supplied the belt to Toyota which they fitted it, 2 days after it starting squealing for the first few minutes till the engine began warming up. It's just gotten worse and sounds rotten when you start it and quite embarrassing . I've had all the pulleys off and replaced a few but still the same noise. Ive got it booked in on Monday to have the bullbar mounts replaced as part of the recall which I only was contacted about the other day. They are going to check it out and hopefully replacing the belt with the genuine Toyota belt might fix the problem. Ta
          Black 120 Grande 2003 "MY4BEE", 4L V6 Petrol 4SP Auto, BFG All Terrain 275/65/R17, Rola Racks, ARB Deluxe Bar, AirbagMan OA6011 Airbag's, Bilstein Shocks, Front King Coils, Eclipse BEC108 reversing camera, LightForce Spotties, Ironman Awning, ARB Outback Storage Drawers, Uniden 80ch UHF, Waeco CFX-65DZ, Oztent RV3.
          [URL="http://www.pradopoint.com/showthread.php?29118-MyPradoGrande-s-120-V6"]My Rig Build Up[/URL]
            Seems to be quite a common problem. I had it too. Go for the simplest first - the A/C belt. Easy way to be certain of it being the A/C is to get it squealing and switch off the A/C. Mine would squeal whenever I switched the A/C on. The fix is easy. First remove the belt. Clean the contact surfaces of the pulleys with WD40 or similar. Replace with genuine Toyota belt. Guaranteed to fix it. Cheapskate option but not 100% guaranteed to fix. Clean contact surfaces of belt with WD40 or similar and refit original belt.
              So picked up the car after work last night from Morley Galleria Toyota (WA) & all sorted. The service rep contacted me saying it needed a new belt and now there is no problems. They also checked the idler pulleys and can confirm they were all ok! Very satisified that I wasn't ripped of and they also did an excellent job of the bullbar! Very Impressed!
