polishing out scratchs
  • polishing out scratchs
    Was wondering has anyone got any ideas or products to polish out scratch or deep rub marks in white baked enamel paint work been told its In the clear coat but normal cut and polish won't work thanks
    i used just a no.1 kitten polish and it removed 95%of the scratches . took a lot of rubbing though . TIP . don't use your drinking arm, you may not be able to use it properly for a day or so afterwards.
      Meguiars Scratch-X
        Juice is the go. Exspensive plus you'll need a buffer wheel.
          RE-PO paint doctor
            mate ive tried everything from kitten to mothers and meguires i have had no luck at all i yet i can get a nice shine which im happy with. when it comes to 4x4's majority look good from a distance never close up at the end of the day they are 4wd's not street cars
            [SIZE=5][SIZE=1][SIZE=2][FONT=arial]120 gx 6sp man,tjm gold edition 2",maxxis bighorn,toyota ally bar with toyota super winch,light force xgt hid 50watt,duel batts,safari snorkel,diesel care secondry finer filter,redarc low coolant alarm,turbo timer,gme uhf,hema hn5i nav,tjm basket,red centre roll out awning,diy rear table...[/FONT][/SIZE][/SIZE][/SIZE]
              It is not possible to polish out deep scratches in the clear coat.
              If the scratch extends down to the paint you'll buff through the clear
              coat and then the panel will need to be repainted.
              Either just learn to live with it or take it to a panel repair shop, touch guy etc.
              LeighW
                Wear 'em with pride.
                [B][SIZE=4]ntp
                  Meguiars Scratch-X
                  X 2, if this doesn't get it out it's not coming out safely.
                    Autoglym has an excellent range of car care products including polishes. I have used their products for years and very happy with them. They are available at Autobarn.
                    Like all polishes, if the scratch is to deep it will be a paint shop job.
                    Jeff
                    [SIZE=3]Jeff[/SIZE]
                      I was told that the time to polish out scratches is just before you intend selling it, otherwise if you take out every scratch as it happens there will be nothing left to take the scratches out of.
                      We have a guy in the office who uses T cut to take out every scratch he gets and his paint is getting very thin now.
                        I give my car a good polish each November then spend the next 12 monthes getting some more custom pin striping
                        See ya on the scratchy tracks, Richo.
                          x2 on that comment.
                          The Roo.
                          yep... x3
                          My biggest scratch after backing into the letterbox would have to be one of the more embarrassing war stories
                          Be hard to polish out as well seeing it went to bare metal :evil:
                            so too much polish actually rubs the paint off?...interesting
                              what product do you use?
                              hmmm, any reason why you choose MOvember?
                              [size=1][color=#990000][b]--> Macarthur District 4WD Club Member <--[/b][/color]
                              ::2005 Black Grande Petrol V6::2 x PP Stickers::ARB Deluxe Winch Bar::IPF Spotties + Fogs:: Dual Battery, ABR DBi120 Isolator & Volt Monitor::ARB Portable Air:: Rear Drawer Unit::Trek Table::WAECO 40Lt::WAECO Raps R12U::AMTS Rear Tyre Spacer::HILUX Washers::UHF::Prodigy P3::Stebel Air Horns:: Inverter::CouplerTec Electronic Rustproofing::OEM Roof Racks, Towbar, Hard Wheel Cover::REAR CAMERA to factory GPS::[/size]
