What is the repairer suggesting and do you trust them (ie: reputable etc)
Unless you are a mechanic then steer clear of any sort of modding or changing to something different. There are always problems as another poster stated.
If it was in my shed I would probably do the following;
The head is off so drop the sump and pull the rods/pistons. Visually check the bearings - did she grab one? If not then I would take it that it didnt get so hot for damage to the oil side of things.
Visually check the pistons. Visually check the bores. If they seem fine then a hone and new set of rings and conrod bearings. Dont worry about the mains.
Reassemble.
Cylinder head off to the head reconditioners for a full recondition. May as well as this normally takes the brunt of the heat.
New water pump, new thermostat and timing kit. Reco injectors. Dont worry about the pump.
Recore on the rad (or a new one)
New hoses.
Reassemble. Fit a good quality gauge temporarily so you can really watch it.
Start and is should be fine. Watch the guages. Shut down if it starts to get hot. Check the cooling system.
The chances of the block being damaged IF the bearings hadnt grabbed is pretty slim IMO.
Your truck is right for a long time.
Reassemble.
New hoses.
