6 stack cd player
  • 6 stack cd player
    we purchased a 2003 gxl 12 months ago along with other optional extras was a sat nav unit witch incorporates cd unit what i cant work out is it supposed to have 6 stack cd player but will only take 1 cd at a time can anyone help.
    If the satnav is a genuine accessory then the CD stacker is under the passenger's seat. The DVD drive for the satnav is under the driver's seat.
      yeah satnav is genuine toyota fitted unit dvd drive is under drivers seat but no stacker unit under passengers seat.Satnav is standard in grande,push a button & screen tilts to access cd player but only takes one cd.
        Correct, unless you can locate a stacker elsewhere like in the cargo area or in the glovebox, it seems you are missing the stacker that is normally under the passenger seat in a Grande. The in-dash sat nav unit only has a single CD player.
          yeah thanks peter thats what i thought looks like the wife will be kept busy changin cds on trips instead of snoozin in the comfy seat.
            The Toyota cd player will read MP3, so convert your music to MP3 & burn it to discs, a lot less changing of cd's that way.
            Thats what I did, even with the 6 cd stacker.
            Now with the 150, I use a ipod classic 160GB player & connect it using the Aux plug.
            The result is lots of music that I like & NO ADDS & boring talk shows.
            Rev
              Rev
              I don't think debker's unit can play MP3s.
                Not sure if it is any help but my 120 GXL has the standard toyota radio 6 stacker and it does play MP3 comes up in the screen saying it. Not sure if the grande's head unit would do the same thing ?? you would think so if the GXL does......Cheers Steve
                  The early model's satnav can't play MP3s. So it'll depend which model was installed.
                    Rev
                    Ok then , that will be frustrating for the cd loader /unloader.
                      I'm constantly amazed at how many variants Mr T makes for different markets - got to be crazy expensive!
                      I have a UK-spec LC5 - the equivalent in most respects to your Grande.
                      But - under the passenger seat I have an audio amplifier, touch-screen SatNag DVD under the drivers seat and a 6-stack cd changer in place of the little utility space above the glove compartment. The SatNag screen is fixed and doesn't tilt ...
                      HTH
                      2005 120 Series LC5 (Grande) D-4D, Safari snorkel, 40mm bodylift, 50mm ToughDog / AirBagMan suspension lift, custom sliders, ASFIR plates, aux power, HowlingMoon RoofTent, FoxWing, ARB Sahara bar, Goldfish 12k winch, BigCountry roof rack, OEM DogGuard, custom 2" receiver, 30mm wheel spacers, Cooper STTs, Kaymar spare-wheel adapter
                        yeah thanks everyone it dosnt have ipod connections or mp3 just come back from up the north coast for easter towin our caravan wife had no problems with cd changin.
                          Caripodcables do an adaptor to get Ipod/Aux into Prado Stereos, to connect the Ipod adaptor you need to disconnect the Stacker, no problem for you, someone has already done it for you!!!
                          http://caripodcables.com.au
                          Matt
                          2003 Prado Grande TD Auto Pearl White
