6 Stacker CD player missing
  • 6 Stacker CD player missing
    Bought a 2004 vx Prado (built June). All research says this should have a 6 stacker CD player but dash unit only takes 1 CD ? Anybody know why this is so? .
    2004 VX 4litre, 4 speed Auto, Sovereign Bar, Spotlights, Dual Battery System, Towbar, LPG Conversion
    Have you checked under the front passenger's seat?
      it should take 6 cd's ,especially so being a vx, i have the gxl and it takes them.....you have to press the load button before loading each cd in, as it "stacks" them in the stereo unit itself, from memory when you press the button it flashes for a while and then LOAD comes up on the display....the vehicle manual should give you more detailed instructions if you have it....
      2004 V6 GXL, ARB Bar, Cargo Barrier, TJM XGS Gold 2 inch lift,Oricom UHF, AMTS Spotties, Dual Battery, Waeco CFX 50, ABR battery Monitors, Iantz GPS
        This is not meant to insult you but you do realize the in dash CD player is a 6 stacker ?? You load one CD at a time by pushing th load button on the left hand side at the top of the unit ?? There is no stacker under the seats like in the 90 series prados....Cheers Steve
          This picture shows the symbol saying 6 Disc
          [IMG][/IMG]
          This one shows the load button top left
          [IMG][/IMG]
          Sorry pictures not super clear just quickly took them with my phone with very little light..........Cheers Steve
            Hi all, thanks for replies but I don't have anything under passenger seat nor does my in dash unit have a load button or a picture of 6 cd's. It looks different than the picture from Steve m. I have tried everything to insert more CDs but won't take them. Manual describes using the 3 and 4 preset buttons to load CDs however mine don,t have this function. Does anybody know if earlier models only had a single CD unit? Thanks...jurgs
              Sounds like its just a single CD unit then. The previous owner could have changed it over for some reason
                Actually I may have been wrong with my comment now I think of it. I know if you get the grande GPS unit as an option there is a stacker as the head unit only holds one cd. Maybe yours is the GPS unit ?? OR has it been changed to an after market unit ?? Cheers Steve
                  Does it look like this http://www.lcool.org/technical/120_s...av/satnav.html if so its been changed to the GPS unit from a grande.......also was an option......My mates VX 06 is the same head unit as my GXL which is inbuilt 6 stacker......Cheers Steve
                    My unit is not GPS unit as your link shows. Looks reasonably simple. Has mp3 logo but not stacker. my vehicle is jun04 so would be interested to see if anyone has one from prior to this date with a stacker. I also note in your earlier photo that you seem to have a larger display area above radio. Mine is smaller and only has a clock and outside temp here. Cheers jurgs
                      Na mate thats all myn shows as well. Its only the grande with some extra read outs, not the VX either......Maybe pre 04 didnt have stacker ?? Cheers Steve
                        Specs from redbook say 6 stacker in o4 model (in dash like the GXL) http://www.redbook.com.au/cars/resea...&Ridx=3&eapi=2 Cheers Steve
                        17" Alloy Wheels Fog Lamps - Front
                        6 Speaker Stereo Guard - Sump
                        ABS (Antilock Brakes) Headrests - Integrated 2nd Row
                        Adjustable Steering Col. - Tilt & Reach Hill Holder
                        Air Cond. - Climate Control 2 Zone Independent Front Suspension
                        Airbags - Driver & Passenger (Dual) Intermittent Wipers - Variable
                        Airbags - Head for 1st Row Seats (Front) Leather Gear Knob
                        Airbags - Head for 2nd Row Seats Leather Steering Wheel
                        Airbags - Side for 1st Row Occupants (Front) Limited Slip Diff
                        Armrest - Rear Centre (Shared) Long Range Fuel Tank
                        Audio - MP3 Decoder Map/Reading Lamps - for 1st Row
                        Body Colour - Bumpers Mudflaps - front
                        Body Side Mouldings - Colour Coded Mudflaps - rear
                        Brake Assist Power Door Mirrors
                        CD Stacker - 6 disc In Dash/Cabin Power Steering
                        Calipers - Front 4 Spot Power Windows - Front & Rear
                        Central Locking - Remote/Keyless Rear Wiper/Washer
                        Centre Differential Remote Boot/Hatch Release
                        Chrome Fittings Remote Fuel Lid Release
                        Chrome Grille Roof Rails
                        Coil Springs Seat - Driver with Electric Lumbar
                        Control - Electronic Stability Seatback Pockets - 1st Row (Front) seats
                        Control - Hill Descent Seatbelt - Load Limiters 1st Row (Front)
                        Control - Traction Seatbelt - Pretensioners 1st Row (Front)
                        Cruise Control Side Steps
                        Disc Brakes Front Ventilated Spare Wheel - Rear Mounted
                        Disc Brakes Rear Ventilated Sunvisor - Illuminated Vanity Mirrors Dual
                        Dual Range Transmission Tacho
                        EBD (Electronic Brake Force Distribution) Tinted Windows
                        Electric Seat - Drivers Trim - Velour
                        Engine Immobiliser Woodgrain - Inserts
                        Flares Body Coloured
                          jurgs : jan 2003 - september 04 :
                          gxl : 6 stacker plus tape vx : same as gxl grande : gps + 1 cd in headunit , followed by six stacker down under passenger seat
                          September 04 - Jan 2007
                          gxl : 6 stacker with mp3 vx : same as gxl grande : gps + mp3 + 4 stacker in headunit
                          Jan 07 -last model 2009
                          gxl : 6stacker, auxilary input , bluetooth headunit vx : same grande : gps + bluetooth + auxillary + 4 stack incd...
                          if yours is a single cd unit, sounds like it is from a GX unit as they have the single mp3 compatible unit.
                          [b][i][u]Toyota Landcruiser Prado 07' update Grande[/u][/i][/b]
                          Metallic Burgundy including upgrades (if you call these that here on pradopoint :P) for the avg. softroader.
                          Sovereign Bullbar with hella spotties.
                          Roofracks
                          Genuine rubber mats/cargo mat
                          Bonnet Protector
                          Hard wheel cover
                          Reverse Sensors
                            Also don't have an electric driver seat so not all correct on Redbook . Jurgs
                              http://www.carsales.com.au/dealer/de...&cr=1&__N=1246 1247 1252 1282 4294962861 4294962685 1216&silo=Stock&find=vx|CarAll Check this link out, You may need to copy the last bit as well that is in black not coming up blue like the link ?? Also what I did notice was all the 120 04 mods with 4 speed auto had this head unit. The 5 speed autos had the same unit as mine so Im presuming yours is 4 speed auto ?? cheers Steve
                              Scroll through the pics there is a close up of the radio unit which Im presuming is your one ??
                              Steve M
                              Addicted PP Member
