V6 auto low idle in gear
  • V6 auto low idle in gear
    Has any one experienced this problem with their prado every now and then when you pull up to a stop in gear the idle drops to 500rpm and some times lower, feels like its about to stall.
    anyone know of any fixes or what the problem could be??????
    Cheers.
    Most likely the ISC is faulty, not sure if Toyota use a seperate solenoid or
    if it's part of the throttle body, maybe someone else knows.
    Try turning on the aircon and see if the same thing happens.
    Leigh
      from what i can see i cant find the ISC. my thinking is its controlled the fly by wire throttle body from the ecm but could be wrong.
      and yeah when i put the aircon on its fine idles at about 650-700rpm
        mine had the same thing, but cleared up after a service and a long weekend away , mine is not a daily drive thou cause i have a work ute , so it could have just been some good ks on the road clearing it up also
