Speedo accuracy
  • Speedo accuracy
    I'm amazed at the speedo in our new Prado.
    Every other modern vehicle I've owned since I bought a GPS back in '99 has shown to have a speedo error of about 2~4%, I always figured it was so the manufacturers gave themselves a margin to prevent people from claiming they got a speeding ticket even though the stock speedo said they were not speeding.
    My Prado reads SPOT ON! :shock: When compared to either of my 2 GPS units, the indicataed speed equals the satellite derived speed.
    No longer can I afford to do 110km/h on the gauge knowing that it's only about 105km/h and thinking the cops won't bother to pull me over, 110km/h in a 100km/h zone, they will most likely pull me up.
    Has anyone else notice this with their speedos?
    Drew.
    Speedo in mine (2003) reads 100 and GPS reads 100-101
    With the standard tyres on vehicle.
    John
    John
      In my 90 series, the speedo and the GPS are always an exact match. (stock tires)
      '97 RZJ90 GX 3RZ-FE 2.7
        When I had my factory tyres on it was 100% spot on to the GPS. Now I have fitted BF Goodrich All Terrains (my choice) it has thrown the speedo out. Now when I am travelling 110 kmh on the speedo, in fact I am doing 115 kmh.
        Only downside to fitting tyres with a different profile. Whatever the incovenience this causes is far out weighed by the off road capabilities of these tyres.
          My speedo underreads by 1-3 km/h according to my GPS.
          Bearing in mind however that no GPS is 100% accurate, I take it with a grain of salt.
          [i]I remember when sex was safe, and flying was dangerous![/i]
            WA 1968, can you tell me about the BFGs? I've just bought a 120 series GX, I live in the WA desert and am wondering if the BFG ATs are worth the cashish... Does anything else work in size 17?
            Cheers, Gordon.
              Hi Drew.
              On the recent WA meetup to seabird we had an in convoy speedo test.
              I have the cooper st in 265/70/17 and my gps was maybe 1 to 2 K under dash speedo reading. Almost identical, but that with about 30,000k of wear.
              Chippy on the other hand was reading about 6 to 7K's slower than mine if I remember correctly at the same speed . Justo and leachy were there also so we had at least one with standard rubber.
              We were on cruise and staying pretty close.
              When the tyres were new it was a little worse, I did a speed refrence back then and it is posted here somewhere.
              And wildmangordo, The coopers discoverer ST's are prety good in 17" and there are plenty of bridgies out there too.
              Jeff.
              W. C. Fields (1880 - 1946)
                My speedo consistently reads 5km/hour more than what 2 GPS's running side by side for comparison show so at 100km/h on the speedo the 2 GPS units are reading 95km/h.
                Vehicle is current model D4D and I was told by Toyota that this is normal and that speedo is not allowed to read the other way around (doing say 100 on the speedo and actual is 105)
                Gives me some leeway for when I fit bigger tyres at changeout time.
                06 GXL D4D, 6spd, Snorkel, ARB bar, XS900 50w HID lights, 55W HID Headlight upgrades, T/bar, 7" GPS, QStarz data logger, 52L Bushman Fridge, Premier winch, Sandgrabbas, GME TX3440, AE4705 antenna, Scangauge II, Dual Batteries, Aero bars & rack, Drawers, 2" Ironman/Rancho/King lift, Under bonnet compressor, Black ducks, Voltage booster, Rear table, AVE TPMS,
                  2009 Speedo accuracy
                  Just noticed that with the 265/70/R17 tyres the speedo on the new Prado is almost accurate in comparison to my GPS. Has anyone else noticed this? I'm wondering whether Toyota has done this based on 2 things, safety (people drive slower thinking they are going faster :evil: )or they know most people put bigger tyres on these beasts.
                  Doug
                  Edit: Topic merged, please use search button to find relevent threads before starting new ones. - Mod
                    Re: 2009 Speedo accuracy
                    Yes, this has been covered before in numerous threads
                      Re: Speedo accuracy
                      My speedo reads 110 and my gps shows 108 so its not that bad.
                        Re: Speedo accuracy
                        My 2005 prado read spot on with the standard tyres and therefore read slow when i on the BFG's. My current 2009 Prado was reading fast with the standard tyres but now with the BFG's is reading spot on. I have been told on several occasions that the speedo in all knew cars must read fast, ie you are going slower than what the speedo reads.
                          Re: Speedo accuracy
                          ADRs require the speedo must not read any slower than true speed but they can be as much as 10% faster than true speed and they don't have to be any more accurate than that.
                            Re: Speedo accuracy
                            90 series standard tyres Cooper ST (265/70R16) GPS 100 speedo 103
                            265/75R16 BFG MT GPS 100 speedo 99
                            Nissan pathfinder...(work car!) GPS 111 speedo 119
                            The biggest issue I have with this inaccuracy is that speed limited trucks are limited to 100 'real' km/h.....If anyone is sitting on 100km/h or little below according to their speedo, they could easily be only doing a 'real' 90km/h. Any truck behind them & overtaking them they will claim is speeding!
                            PS overeading speedo's are great for fuel economy too!
                            Thank heavens for GPS's!
                            Richard
                            2011 GXL TD Auto Prado Silver
                              Re: Speedo accuracy
                              My Mazda BT50 is out by exactly 10%. At 110K's on speedo you are actually doing 100k's. Tried to get Mazda to fix it under warranty but the replied all mazdas are like that and mazda wont allow the dealers to hook up the computer and correct it.
                              Didnt realise it until bought a new GPS and noted the difference, no wonder others were passing me.
