Knock, knock, knock, knock
  • Knock, knock, knock, knock
    OK, after getting under the beast and playing around with what at first appeared to be a loose exhaust system I still have this mysterious knock from the rear. It only happens as the car comes to a halt. It's slightly muffled and definitely coming from the back end of the car. I emptied the drawers, removed the tool kit, dumped the Engel but the noise persists. It's a subtle knock, knock, knock, knock. It's like four or five knocks in about 2 - 3 seconds. Doesn't happen when accelerating or cornering. Shocks, brakes, wheels, tyres, suspension all feels good. Ideas?
    As silly as it sounds, check your jack is securely in place... I always screw it up a few notches to put pressure on the top mount and hold it firm...
    Smithy - 120 D4D
      Yes I have exactly the same knocking noise. I just put up with it.
        Thanks fella. Yes, full of fuel. The jack lives in a canvas bag down the side of the drawers so it doesn't rattle at all.
          Rear door, striker & or support catch adjustment.
          To diagnose rap some nitto ( elec tape) around the rear door support, the metal part on vehicle that the plastic on door goes into when it closes, that will make it tight & hide the noise if that's it.
          Then drive if he noise is gone, remove the tape & adjust hinges, catch/support & striker as necessary.
          Look for marks on striker to see if its been hitting.
          Jeez the stuff can be hard to explain, hope you can un jumble it & that helps.
            Mine does it, doesn't matter how much fuel is in it.
            I always assumed it was the tail shaft. Dunno why. Just a guess.
            More to come!
              yep mine does it to, but only on reasonable hard braking. If braking soft I don't hear it at all. To me it sounds like its coming from rear left. Also doesn't matter how much fuel is in mine could be full or empty still does it.
              Andrew
              2005 VX Diesel - [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12823"]My Rig Buildup[/URL]
              [URL="http://www.fuelly.com/smallsig-metric/65233.png"][img]http://www.fuelly.com/smallsig-metric/65233.png[/URL][/img]
              [B]Bitumen - A blantant waste of taxpayers money![/B]
              [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12197&start=0&st=0&sk=t&sd=d"][/URL]
                It's definitely coming from the fuel tank area towards the rear of the car and only during braking, not cornering. The rear door is not the culprit. I think I can remember reading about this some time ago. As there are no issues with the rear driveline, suspension etc I won't worry about it. Now to find that frigging rattle under the bonnet.
                  While we are at it, I've had a knock knock since April in Fraser.
                  Right side, it sounds like its coming from the r/h/f mudflap area.
                  Checked side steps etc, in case not tight bolts.
                  Checked over front suspension. No luck yet.
                  Anyone with any ideas?
                    Dave, is your rattle under the bonnet those crappy plastic inner guards? They move around on the clips that hold them in , especially after a bit of dirt work.Neil
                      Who is there?
                      Go on admit it, it's too hard to resist!
                      mlc
                        qui est la? qui est la?
                          Inner guards - check, bonnet scoop - check, lights - check, grill badge - glued on check, engine cover - check. There's still something rattling here only at idle and in gear. Will keep looking and poking about.
                            Check your battery clamp i had craked the top plastic support brace which would then let the clamp rattle agains the battery tray
                            "Drive down that track really fast, if something gets in your way turn"
                              Who is there?
                              mlc
                              Yes mlc it is, or should I say was.
                              REV
