Hi all, been awhile since I have posted anything. Does anyone know whether its possible to get the towing capacity lifted from 2.5 ton to 3 ton? A mate told me that ARB etc can do this with upgraded springs,shocks, and brakes etc. I have just discovered that the caravan I purchased weighs 2.8 ton fully loaded and the ball weight is 380kgs. Not good!
Upgrading the tow rating capacity.
My limited understanding is that GVM upgrades can only be done at time of registration from new. Unaware of a kit for the Prado, but plenty of options for a 200. It's quite interesting when you look at the figures though the kerb weight of the 150 diesel is 2330 and GVM is 2990' this only leaves 660 kg for passengers, accessories, equipment and your ball weight. The gross combined Mass is 5370 kg, so if your rig is already at GVM capacity it only leaves you 2380 kg, towing capacity out of a possible 2500 kg.. I suspect there are a hell of a lot of overweight rigs and vans out there.150 with stuff bolted on!
Originally posted by JPH View PostMy limited understanding is that GVM upgrades can only be done at time of registration from new. Unaware of a kit for the Prado, but plenty of options for a 200. It's quite interesting when you look at the figures though the kerb weight of the 150 diesel is 2330 and GVM is 2990' this only leaves 660 kg for passengers, accessories, equipment and your ball weight. The gross combined Mass is 5370 kg, so if your rig is already at GVM capacity it only leaves you 2380 kg, towing capacity out of a possible 2500 kg.. I suspect there are a hell of a lot of overweight rigs and vans out there.
380kg ball weight sounds like a lot for a 2800kg Van.
Toyota ball weight is 10% of tow capacity.
LC200's tow 3500kg so ball weight 350kg.Dan
Just because you might be able to get approval to tow 3 tonnes, does not mean that it will be safe to tow it (eg braking) or good to tow (pulling it up hills).Michael and Kelly
Well, do you know how many of these supposedly 3.5 tonne towing rated BT50, Izuzu Dmax, VW etc 4wds are falling over towing vans? Lots. We see them all the time. You rarely see a LC 200 or similar large vehicle having dramas but those new generation dual cabs towing large vans are rolling over like dice on a craps table at the casino.Dave
Originally posted by Bushbasher View PostWell, do you know how many of these supposedly 3.5 tonne towing rated BT50, Izuzu Dmax, VW etc 4wds are falling over towing vans? Lots. We see them all the time. You rarely see a LC 200 or similar large vehicle having dramas but those new generation dual cabs towing large vans are rolling over like dice on a craps table at the casino.2016 1GD GXL 6 speed auto, ARB colour coded summit bar, LED driving lights, duel batteries, BF Goodrich tyres, window tint.
Old man has a LC200, it is a great tow rig, is very planted on the road when towing big weight and no shortage of grunt. Funny enough my prado feels better towing up to 2.5 ton than the dual cab hilux at work (both D4D hilux is auto) but the prado seems to handle it better plus the brakes on the hilux are terrible!
Cheers2016 1GD GXL 6 speed auto, ARB colour coded summit bar, LED driving lights, duel batteries, BF Goodrich tyres, window tint.
I have had my 120 upgraded to 3000kg tow & 300kg ball. All done through RMS (NSW) certified engineer. As a result the GVM has been upgraded to 2990kg & the GCM to 5600kg. Added air bags & tow bar from 150 series. Also removed third row of seats (now a 5 seater).All up cost $1800.00 All changes noted on rego papers plus I have a certificate from the Engineer.....Michael Dudley from ASRC Engineering 0414586027. Process was completed in Nov 2013.
Originally posted by ROSCOE T View PostI have had my 120 upgraded to 3000kg tow & 300kg ball. All done through RMS (NSW) certified engineer. As a result the GVM has been upgraded to 2990kg & the GCM to 5600kg. Added air bags & tow bar from 150 series. Also removed third row of seats (now a 5 seater).All up cost $1800.00 All changes noted on rego papers plus I have a certificate from the Engineer.....Michael Dudley from ASRC Engineering 0414586027. Process was completed in Nov 2013.[B]Steve[/B]
MichaelMy 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
