    I would be too mate.
    Want some nice fj cruiser wheels on my 120
    ps, how much were those bfg's fitted? I'm in need of new tyres soon and want some nice at's
    Paid $350 a corner fitted and balanced. Tempe tyres in Sydney have them for $325 fitted and balanced as well.
    • New DBA T2 rotors up front, Bendix brake pads all around and a helping of Toyota DOT 3 fluid. She does pull up harder now under heavy braking. The pedal still seems kinda soft like it use to though, but apparently the 120's were like that I heard?
      1979 BJ40
      1992 FZJ80R
      1997 HDJ80R
      2005 GRJ120R
      • A
        [ATTACH=CONFIG]21468[/ATTACH]
        [ATTACH=CONFIG]21469[/ATTACH]
        Shiney
        Hope you put that backing plate/shim back in with the new pads
        [LEFT]Silver 150 Facelift
        • Originally posted by Falco80 View Post
          Nice work! I'll be doing the same shortly!
          Apparently we can use Dot 4 fluid as well, as it has the same properties as Dot 3, but higher boiling point?
          • Originally posted by chewy7 View Post
            There is something with dot4 fluid that messes with the seals in toyota brake systems, mostly abs modules. I have seen them leak with the only explanation being dot4 used. Some use it and don't have problems, for me it's not worth the risk, on mine and my customers cars.
            • Originally posted by AussieAndy View Post
              Thanks for the heads up! I'll be heading back to repco and swapping mine out for Dot 3, just to be on the safe side!
                guess i'll be going with the bridgestone d697 then lol
                  noice
                    I have the D697's currently and will lean towards the Toyo ATII due to higher load rating and cheaper pricing.
                      A
                      Shiney
                      Yep, sure did. Oddly, on the rear brakes only one pad out of four had a metal backing plate. Someone had been there before and was obviously not very thorough. Makes you wonder about some of the muppets working out there.....on vehicle braking systems! :-?
                      The Toyota Dot 3 fluid is not expensive and that is what is recommended. As AussieAndy mentioned, is it worth having something in the system leak for the sake of a different brake fluid. I'm not driving a race car, so the Dot 3 is fine.
                      1979 BJ40
                      1992 FZJ80R
                      1997 HDJ80R
                      2005 GRJ120R
                      • Installed some Narva Intense H4 bulbs (and the matching parkers) in the headlights and Intense H3 bulbs in the ARB bullbar fog lights.
                        The headlights were easy as. The fog lights were a PITA and took hours due to rusty nuts/bolts as well as an existing wiring fault I had to fix for the fog lights whilst I was at it. 2 fuses and a wire crimper later and it's all good.
                        See my Facebook post in the Aussie 120 Prado page for the pics.
                        BiLLz0r
                        • Drained the oil out of the diff lock line - again. This is a must do job every time you think you may need the diff to work.
                          Rusty.
                            just did a little look up, the toyos look alright but that speed rating is pretty low for someone like me. We don't carry a lot in the car either, compared to what everyone else here has (drawers in the back, roof racks with house supplies on top etc).
                              The higher load rating usually means better puncture resistance
                                Ahh... Didn't think of that lol. Think I'll still lean towards the d697s anyway. Too convInced with them
