Replace air conditioner evaporator
  • Replace air conditioner evaporator
    Hi,
    I spend days looking on line about DIY replacement of air con evaporator. I was quoted $1500 because dash removal was required..
    Prado GRJ120 2003 GX
    Ended up trying myself as I had removed my centre console before to replace my stereo.
    YOU DO NOT NEED TO REMOVE THE DASH TO REPLACE THE AIR CON EVAPORATOR!!!!!
    All you need to do is remove the glove box to expose the fan inlet module. There are 2 nuts and 2 bolts to remove to allow removal of the assembly (fan and plastic housing - Need to wriggle a bit to get it out). On the side of the air on box there are about 6-7 screws that need to be removed to expose the evaporator (this is just behind the heater coil).
    You also need to remove the under dash covers on the drivers side so you can access the other side of the air con box.
    Unscrew the 2 allen key bolts holding evaporator inlet and outlet pipes. Slide old evaporator out and replace with new one ( I paid $220{cool drive, Darwin} for a new evaporator, $480 from Toyota. I have been told that they are the same, but not sure about that).
    Should only take about 4-5 hours first time (2-3 hours to do again - removal and installation)
    I am only posting this because I could not find any help in replacing the evaporator without spending 6-7 hours removing the entire dash.
    Happy to help anyone looking at doing this themselves. CAN BE DONE IN ONE DAY AND SAVE YOURSELF $1500.
    Andrew Es
    Originally posted by esman View Post
    Hi,
    Andrew Es
    Great 1st post!
    Yes my air-con specialist ( I sublet air-con work) he uses cool drive & says its the goods.
      Hi,
      Andrew Es
      Mine was replaced a few months back by an a/c guy and yes no dash removal required. He charged about $200 labour to do it so I was happy to pay it.
        Good to know, thanks
          Just did mine. Was quoted $2000 for the job. Found this post. Stripped everything out an about 1.5 hours. Got a aftermarket evaporator from Covs (Perth) for $180. Installed it, put everything back together in about 1.5 hours. Taking it for regas next week ($200).
          esman, you are a legend for saving me 1600 of Australias finest dollars.
          P.S. One thing to note though. When you have removed all the covers and cubby on the passenger side. There is a section of plastic trim that runs around the bottom of the cubby hole. This had previousley been cut out of my car and this made the removal of the fan housing substantially easier. I assume that prior to me owning it someone had done some work in this area before. Anyway this is not exposed once all the covers are back on and although it has one less attachment screw it has not caused any issues in the 3 years I have owned the car.
            Great 1st post!
            Yeah i'm a qualified automotive aircon tech(out of the business now for a few years), we had been using cooldrive for the good part of 15 years & havent had a drama with their stuff.
            If you have a Toyota & you take it to an aircon place & they quote you exorbitant prices for removal of the dash to get the evaporator out, turn around and walk straight out.
            Pretty much all toyotas have an evaporator box that can be removed seperately to the rest of the hvac box.
            All you need to do is remove the glovebox & a few bolts & the pipes from the engine bay and its out!
              Thanks esman,
              been without a/c since returning from Fraser over the Sept school holidays. Unable to find leak first time around, gassed her up, lasted about a week and a half. Take it back and they inform me the dash needs to come apart for the evap to be done. Remembered seeing this thread and decided to look after it myself. Just over an hour and all sorted. Back for regas this week.
              cheers
              Brandon
                yep redcliffe auto electrics did this in brissy through the glovebox
                Address: 220 Anzac Ave, Redcliffe QLD 4020
                Phone07) 3284 8459
                  Hello Andrew,
                  I will be doing this project on Friday(December 11). Hopefully, you get this message in time to offer further advice.
                  Purchased a new evaporator(60,000Ksh) from Toyota. Didn't trust the second-hand unit dealers here in Nairobi, Kenya.
                  Do you have a step-by-step list OR photos?
                  Appreciate any learnings you can pass my way.
                  Regards,
                  Hi,
                  Andrew Es
                    Hi there,
                    I tried to do this in my KZJ120 Prado 2003. But couldn't actually go further than removing the fan with the plastic housing. I was wondering if someone has any pictures of the process. I am attaching some myself, probably someone can point out where to go next.
                    Thank!
ID:	652845Click image for larger version
                      Originally posted by ernieprado View Post
                      Hi there,
                      Thank!
                      [ATTACH=CONFIG]21987[/ATTACH][ATTACH=CONFIG]21988[/ATTACH]
                      Ahh, Left hand drive vehicle?
                      Looks like youll have to go in the other side.
                      I havent had any experience with LHD Prados, but a lot of the car companies that sell converted vehicles wont actually convert the HVAC boxes - which means your evaporator will most likely still be on the left side of the vehicle under the steering column.
                      That big vacant space is where the steering column usually sits on the RHD prados.
                      So drop the covers around your steering column and it should give you a better idea.
                        Excuse my ignorance but exactly what is it that goes wrong with the evaporators, Corrosion, valves or what?
                        2009 120 GXL D4D, TJM Bull Bar, Winch, Safari Snorkel, ARB Lift, ARB Lockers, Black Widow Drawers
                          Thank you Topic97,
                          I will give it a try and will let you know the outcome later.
                          Mule,
                          In my case, i've been told there is a leak due to corrosion and apparently is very common in my model (prado kzj120 2003)
                            Mule,
                            In my case, i've been told there is a leak due to corrosion and apparently is very common in my model (prado kzj120 2003)[/QUOTE]
                              The alloy has a limited lifespan before it starts to break down because its so light & under so much pressure, and the oodles of moisture they create doesnt help all of this.
                              They split, or can rub holes too.
