roof rack fuel consumpion
  • roof rack fuel consumpion
    hi all I have a 2004 120 v6 manual and want to fit a roof rack I am going to get a rhino pioneer platform and was interested as to what fuel consumption gains people have experienced by fitting a roof rack TIA
    Around 0.5L/100km increase in fuel consumption
      Don't worry about the increase because now you can carry a couple of extra jerries on your new roof-rack to feed that thirsty V6.
        thanks amts I had a steel rack on my 80 series and it was a big increase about 3l/100km that's why in going alloy this time. come on bushbasher there not that bad it just depends how hard I drive it lol
          Didn't really notice much change in fuel consumption, but did notice the increased noise. I guess in a diesel you probably wouldn't hear it
            The Pioneer Platform is low profile which is the best thing about it. Was your steel rack more like a cage? 3L/100km increase is a bit high. Did you do a lift or bigger tyres at the same time?
              It was a cage but nothing else done at the same time
                The shape will generally make a much larger difference than the weight.
                2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
                2008 Jayco Dove Outback - "Davo"
                  The diesel can suck through the juice too if you drive it a little fast.
