Just a few ramblings as I plan a week off work to do a few jobs to the car and around the house
In regards to fitting the battery and tray into the gap behind the headlight (once the PS reservoir is moved) Does the lower bracket for the air intake just get removed?
I cannot see a way to get the tray in without removing the bracket? (i'll be fabbing my own tray)
Also is the rubber "thingy" in the photo a drain for the air intake system? I took it off and got a heap of dust out of it, I'm assuming that under air intake the two flaps of the rubber seal together? but they're there to allow some sort of drain once the motor is off?
cheers
cheers
