I just had a sniff in the hole where the jack sits. I found when the dealer fitted the reverse sensors and towbar electrics, they left the relays just floating around and the control box thrown in there. Is this normal? :?
Standard of fitment OE accessories
Should be all cable tied to the loom.
Hi blkmav90 - see my experience here http://www.pradopoint.com/viewtopic.php ... highlight=
Slack bastards - obviously not their $60k vehicle. Make sure you check all the grommets are seated properly otherwise you'll have a cargo area full of dust next time you're off road.12/2007 VX D4D Auto - Silver Ash
My experience was exactly the same as blkmav90. I heard a noise in the jack compartment and the sensor box had been stuck on with double sided tape which had let go. I fixed it with a couple of cable ties and all good. Then I noticed the wiring was hanging down because again the double sided tape fell off. The dealer looped cable ties around the wiring and the rear bumper supports. Very roughly. 10k service next week and an item to be fixed. Not good enough.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
You are better off donig it your self, at least you know the jobs done properly & you save a fortune in the process
I wouldnt be game to let Toyota fit accesorys to my vehicle2007 D4D auto, Tunit Power Module, Scan GaugeII, Bilsteins & lovels HD, raised 50mm front & 60mm rear, 10,000lb Tmax winch, 7/16th Amsteelblue synthetic 23,000lb winch cable, TiTan HD winch solenoid pack, Outback draws with fridge slide & 50 litre Waeco, Ryno roof rack & Alloy Cage & extra set of Rhino HD Roof bars x 3, TJM type 15 steel Bullbar powder coated silver, Dual battery setup with custom tray, Bosch Navigator spots with 55w HID kit, Sand Grabber mats, Toyota Tow Bar, Sensor Touch Electric Brakes, Cooper ST 265/70/17 tyres, Uniden remote head UHF radio, Modified Milford Cargo Barrier, Extra power points in the back run with 10mm wire for fridge & inverter, Anderson plugs with 10mm wire front & back for the camper & compresor conections. 7 inch in dash JVC DVD player with bluetooth & Ipod adaptor, 39DB Stebel High Power TM80/2 Magnum Electric Horns. JL Audio 300/4, 300/2 power amps, Pioneer TS-C160R front splits & TS-D161S rear speakers & 12" Pioneer sub
