hi , car is Prado 2004 v6 auto , we are looking at getting a Jayco Outback camper , tare weight is - 1185kg and tow ball is 132kg this is the unloaded weights , vehicle has standard suspension and original tow bar , any help with suspension , ( old man emu ) ect , and if a better tow bar would best, wont be used for real rough work mainly dirt roads and tracks , regards john
120 SERIES standard towbar
With those weights the standard suspension and towbar should be fine as long as in good condition. And as 404pug said make sure the towball recall has been checked.David (AKA Grumps)
http://www.pradopoint.com/showthread...-Towbar-recallOriginally posted by kjoy064 View PostHi guys, sorry to thread deviate but anyone have the link for the tow bar recall.
Towbar Recall
thanks to 404pug and dagree , ect , I have 2 recall stickers inside front door , dated - 13/10/11 Code No 0631H and - 20/1/14 Code No 3606D , and a sticker on towbar - Max Towbar Capacity 2500kg and Max Load Downward 250kg , so it should be well in the weight range , this original tongue just doesn't look very strong compared to an " ALLIN " OR " Hayman Reece " which had larger flat tongues that I have had on previous cars , I will get my local Toyota yard to write down what were the 2 recalls they had done for the previous owner and check that mine has been done , thanks guys for the promt replies , john
